help with PIA VPN speed
Hi,
I am trying to set up my PIA VPN to the eastcost server for my PS4
when running a speed test without vpn I get 50download/5upload on average, however when using through the eastcoast server I get 2/3 download, 0.4 upload,
can you please help?
I am using;
client
dev tun
proto udp
remote us-east.privateinternetaccess.com 1194
resolv-retry infinite
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
auth-user-pass
comp-lzo
verb 1
reneg-sec 0
<ca>
Hey Cran, welcome to the forum :)
Can you make sure that you are on the latest version (1.03.5m) which can be found here.
Happy Xmas!
Hi Crossy,
thanks - this seemed to have worked, up to 25 /4 mbps.
Thats actually really fast through the Netduma :D Because everything has to be encrypted/decrypted for the VPN, it takes much more processing power which is why you won't get the speeds you can on your PC :)
