Need 1 on 1 for BO3 settings
Need 1 on 1 for BO3 settings. I thing my cloud settings dont apply, becouse for me there is no dedi server showing in EU only Irish dedi. If anybody had time I would be very happy. Thanks. Sorry for my bad English
All I'm getting is the Irish servers also mate, even when I load the game up and it shows you the servers, if I put my location next to the server down on the south of the U.K. And the other 2 closest servers in Europe then I still can't get on them, I only ever get the Irish one or something showing up in the U.S 4000 miles away, tried everything but nothing changes
Why do you think something is wrong - just because there are no serves in the US? If so, make your home location as small as possible, load up the game and when you see the padlocks, take  a screen shot. This will show where all the dedis are   :)
There are no paddlogs except two in Ireland (EU) showing of if a make my home location as small as possible. And if I exclude Ireland in host filtering, then Im not getting any games!!!! Thats with strict on and ping assist 0.
Look Crossy. Not showing dedis or paddlogs in EU or are all mislocated. Instead of paddlogs its showing red circles
That's probably just because you've connected to them within the last 2 mins. Either way, if they showed up when the game loads then those are dedis :)
Yes but why i cant find games with strict on and ping assist 0 when I exclude Ireland out of geo filter?
Don't put PA on 0ms. Put it on about 30/40ms :)
try this for some reason. Go to the auto cloud thing and bleeding edge thingy and uncheck them. Click on all the drop downs for all the things nearest them and move to highest number. Is there an apply button? I can't remmeber but restart router. Then recheck auto cloud and bleeding edge click apply again if there is an apply button and restart router. All my games were in Kansas never anywhere else till I did this. Not sure if it helped but everything changed after that. Hope it helps.
