RADDY1993 Posted February 14, 2015 Share Posted February 14, 2015 Hi, i ve just ordered my Netduma router and am very excited to get it wired up and performing as it should. My question is does anyone have any guide or advice for setting the Netduma up with the ASUS DSL-AC68u router running on Sky Fibre. Link to comment Share on other sites More sharing options...
Guest Netduma Fraser Posted February 14, 2015 Share Posted February 14, 2015 Hi, i ve just ordered my Netduma router and am very excited to get it wired up and performing as it should. My question is does anyone have any guide or advice for setting the Netduma up with the ASUS DSL-AC68u router running on Sky Fibre. Hey thanks for purchasing and glad to see youve received it today! Do you have a sky hub > asus > r1? If so I would replace the asus with the R1 and then follow these instructions - http://forum.netduma.com/topic/266-sky-fibre-sr102-black/ Link to comment Share on other sites More sharing options...
RADDY1993 Posted February 14, 2015 Author Share Posted February 14, 2015 Hey thanks for purchasing and glad to see youve received it today! Do you have a sky hub > asus > r1? If so I would replace the asus with the R1 and then follow these instructions - http://forum.netduma.com/topic/266-sky-fibre-sr102-black/ I replaced the crappy SR-102 Sky Hub with this http://www.asus.com/uk/Networking/DSLAC68U/its a great router/modem im hoping to just plug the Netduma straight in and place it in the ASUS dmz. Should that work, i payed alot of money for the ASUS so i dont want to swap it back for the thing sky call a router . Link to comment Share on other sites More sharing options...
Guest Netduma_Iain Posted February 14, 2015 Share Posted February 14, 2015 Hi Raddy yes that should work Link to comment Share on other sites More sharing options...
RADDY1993 Posted February 15, 2015 Author Share Posted February 15, 2015 Hi Raddy yes that should work Thanx Iain cant wait . Link to comment Share on other sites More sharing options...
Guest Netduma_Iain Posted February 15, 2015 Share Posted February 15, 2015 Cheers Raddy please let me know how you get on, also don't forget to upgrade when you get it Link to comment Share on other sites More sharing options...
BL4CK OPS V3TRN Posted February 15, 2015 Share Posted February 15, 2015 Raddy - pleased to see you replaced the crappy sky modem/ router . I have a Netgear top end router with DWRT flashed but have never been able to use it since I switched to sky due to their MER thingy bob !! how did you do that if you don't mind me asking Link to comment Share on other sites More sharing options...
RADDY1993 Posted February 15, 2015 Author Share Posted February 15, 2015 Raddy - pleased to see you replaced the crappy sky modem/ router . I have a Netgear top end router with DWRT flashed but have never been able to use it since I switched to sky due to their MER thingy bob !! how did you do that if you don't mind me asking Do you have your Sky username and password. Link to comment Share on other sites More sharing options...
BL4CK OPS V3TRN Posted February 15, 2015 Share Posted February 15, 2015 I certainly do Link to comment Share on other sites More sharing options...
RADDY1993 Posted February 15, 2015 Author Share Posted February 15, 2015 I certainly do Mine set up automaticly to Sky, what options do you have when you try to connect. My Wan connection options are Static ip, PPPOE, Bridge and Automatic ip, mine is set to Automatic ip. Link to comment Share on other sites More sharing options...
