Jumppy_15 Posted November 22, 2015 Posted November 22, 2015 Hi, after I did the new update to 1.03.5 my connection speeds have become very low. And even after I disconnect the Netduma router and go back to my old Lynksis router my connection speed is still low. It's almost like after I updated the Netduma router it has also affected my Modem. Is that possible? Could the new update have affected how my Modem brings internet into the house and it's speed? Because now no matter which router I use Netduma or Lynksis my connections speeds have disappeared. I need some help please, I'm quite concerned!
Netduma Staff Netduma Crossy Posted November 22, 2015 Netduma Staff Posted November 22, 2015 No, it can't have affected your modem. I'd suggest calling your ISP and asking them to take a look into why you are getting slow speeds
Jumppy_15 Posted November 23, 2015 Author Posted November 23, 2015 Ok thanks. It looks like selecting "reset distribution" and then immediately "update distribution" helped in the Congestion Control screen. Before I kept setting the Playstation's distribution to 90%.
Netduma Staff Netduma Crossy Posted November 23, 2015 Netduma Staff Posted November 23, 2015 Ok thanks. It looks like selecting "reset distribution" and then immediately "update distribution" helped in the Congestion Control screen. Before I kept setting the Playstation's distribution to 90%. Great! Has this sorted the problem?
Netduma Staff Netduma Crossy Posted November 23, 2015 Netduma Staff Posted November 23, 2015 Yes, speeds have gone back up. Nice I'll close this thread as you've got it sorted - feel free to make another if you have anymore questions.
