Error during v 1.03.5 need Help
are you getting any lights on the netduma?
if so make sure all you ethernet cables are plugged in i have unplugged them and didint realize i hadnt plugged them back in all the way.
if that doesnt work ,try to play without the netduma and see if there is a problem with the servers working without it.
then plug in the netduma back in ,theres a glitch i think in the update im not sure ,thats how i got mine to work.
