Ping problem
After installed the new Dashboard my ping passed from 170 to 200.. Which could be the problem..?? The Result of test Is exeptional and no packet loss.. Help me :(
Hi Albo,
How are you testing the ping? Is it through the Xbox dashboard? If it is don't worry what it says on there - it is inaccurate :)
Yes , through the dash. Thanks Crossy..
Ok, definitely wouldn't worry about it then. As long as the Netduma diagnostics show everything as ok its fine :)
 Exeptional Exeptional Exeptional No Loss.. , I couldn't find the problem..
Ok, in that case Xbox is probably just testing to some server far away or something like that :) I'll close the thread as your problem seams to be sorted - feel free to make another with any other questions.
