Netduma problems...
MarkJay74832194432
Well this is my second time writing the whole thing since I tried to put the images and it led me to another page. So it here it goes... again.
Over the past month or so, I have been hard resetting and tweaking the settings religiously, and needless to say, I was frustrated and displeased with the results. Don't get me wrong, it is an excellent router when it does its job. It performed very well within the first few weeks after purchasing with my own personal settings. Unfortunately for me, this is no longer the case. I've tried every single possible combination for the congestion and all other settings for all previous cods as well recently, and kept getting an average to disappointing results. I'm not sure if it's the ISP's fault and there is nothing I can do at this point. For the sake of this post, I'll keep this problem to Advanced Warfare and BO3, even though I'll probably never touch AW ever again...
Just to prove a point, I've ragequitted 20, yup that's right, twenty games in a row last night. I had a very depressing session at that time, bullets weren't registering, people killed me when I shot millions of bullets into their face, etc. You know the typical problems you got before you bought this router. Well I'm still getting those problems.
I want to love this router. I really do. I'm not trying to bash it or anything like that, but I'm just not getting the results that I want to. This router was very expensive and I do not want that to go to waste. I'm not too sure if the problem comes from the router or the ISP. Anyone have an idea?
Crossy, did you get the images?
Hmm, you're getting very low ping games.
Could you make sure Bleeding Edge Cloud is enabled in Settings >> Miscellaneous :)
What does that do? And I still have tons of weird problems with BO3.. I don't know why. Is there any good settings for the congestion control? I have a 50 down and 7.6 up.
That puts you on the latest cloud version (which has been tweeted a bit for Bops3). 70/70 should be good for congestion control with those speeds :)
Damn looks like a pretty stable connection to me,wish I had it.
On the pics with your GF I noticed you had both the PS3 and PS4 enabled at the same time,remember it's opposite enable means disable
@Crossy thank you, i'll give this a shot and hopefully I don't get melted quickly.
@fuzzy clam i know i usually enable both whenever i play cod and disable both when im not. is there a problem when you enable both?
I don't know if there would be a problem but why not just enable the console you're gaming on at the time.I got the same set up as you and I just enable GF on the console I'm using.May not be an issue but just eliminates one of the variables.
