marctec Posted October 26, 2015 Posted October 26, 2015 Hello, I've installed the IP TV service in my home, it's working fine when connected directly to the main router, but don't start up when connected to netduma. I know it's a IP TV receiver and it needs to connect to main router in order to validate the Identification to start the device. here are my IP, can anyone help me how to config in order to connect the IP TV receiver directly to netduma? IPTV Address 10.125.211.33 IPTV Netmask 255.192.0.0 IPTV Gateway 10.32.1.1 Thanks in advance.
Administrators Netduma Fraser Posted October 27, 2015 Administrators Posted October 27, 2015 If it needs to connect to the main router to validate then it may not work, however you could go to Settings > WAN and change to static with the info you've provided above. Might not work but that's the place you can put it
marctec Posted October 27, 2015 Author Posted October 27, 2015 Hello, I've tried different ways but it doesn't work, any other suggestions? I want like to filter this in order to use the congestion control feature. Thanks in advance.
Administrators Netduma Fraser Posted October 27, 2015 Administrators Posted October 27, 2015 You put all those details into WAN and it didn't work? That's the only place you could put them really. I'll talk with Iain tomorrow and see if there is another solution
marctec Posted October 28, 2015 Author Posted October 28, 2015 Thanks dear, waiting a solution for that. Kind regards
Administrators Netduma Fraser Posted October 29, 2015 Administrators Posted October 29, 2015 I spoke with Iain and the suggestion for now is to connect the IP TV Service to your main router, if you then have any problems with congestion we can look into a more complete solution
marctec Posted October 29, 2015 Author Posted October 29, 2015 Hello, thanks for your answer, yes that's how I've connected now, directly to main router. But the problem comes when my wife/son start browsing channels or channels lists from the TV IP receiver, I suffer more lag when playing, around 5-10 seconds after the IP TV buffer is enough to load the channel... As I've tested this 2 weeks directly to main router, I'm asking hot to configure with netduma to avoid this problems and have the rest of family happy. Thanks in advance.
Administrators Netduma Fraser Posted October 30, 2015 Administrators Posted October 30, 2015 If you can get the details of how the TV IP service works we can try to figure something out in a future upgrade to resolve that
