Rainbows&Lollipops Posted September 3, 2015 Posted September 3, 2015 so, I am not sure why. but i am about a week into the R1 (which I LOVE) but over the past few days it beeps, restarts and wipes out most of the settings like, device name, peer ping (I only play destiny), bleed edge, etc.. I have not change a sing thing. any ideas?
iAmMoDBoX Posted September 3, 2015 Posted September 3, 2015 This has been posted before and it is either a lose power connection or it's getting too warm.
Netduma Staff Netduma Crossy Posted September 3, 2015 Netduma Staff Posted September 3, 2015 Can you go to Settings >> Miscellaneous and makes sure that the cookies option is disabled. Also can you make sure that the R1 can't be getting over heated (so it isn't in an enclosed space)
Rainbows&Lollipops Posted September 3, 2015 Author Posted September 3, 2015 This has been posted before and it is either a lose power connection or it's getting too warm. thats odd. I have an inline electrical filter for consistency and the R1 is out in the open... I wonder if the feet it comes with is not high enough?
Rainbows&Lollipops Posted September 3, 2015 Author Posted September 3, 2015 Can you go to Settings >> Miscellaneous and makes sure that the cookies option is disabled. Also can you make sure that the R1 can't be getting over heated (so it isn't in an enclosed space) if I disable cookies, wont it lose my settings?
Netduma Staff Netduma Crossy Posted September 3, 2015 Netduma Staff Posted September 3, 2015 if I disable cookies, wont it lose my settings? Not the important ones, just the ones such such as zoom on the GeoFilter etc. This has fixed the issue you are describing for people in the past so hopefully this (if it works) can be a temporary fix.
