faulko Posted February 3, 2015 Author Posted February 3, 2015 Do you happen to run a ddns on your asus router? Its disabled but thanks for the suggestion. What about Wan Nat pass through? For some reason all the options are on but i never remember seeing these features turned on.
abc123 Posted February 3, 2015 Posted February 3, 2015 WAN – NAT PassthroughNAT (network address translation) is a standard router feature that allows your home network to use only one connection to access the internet from multiple computers. It does this by translating your home computer’s private IP address to your ISP’s public IP address for accessing the internet, and then back again. VPN Passthrough is a router feature which allows an outbound VPN (Virtual Private Network) connection to “pass through” your router’s NAT process. Popular VPN protocols such as PPTP andIPsec do not work with NAT directly, since VPN traffic is encrypted. NAT Passthrough allows the VPN data to pass without any changes by the NAT process. It only does this though, for certain VPN protocols only which you can specify on this screen.
