hi all, today the r3 started playing up big time, connection keeps dropping in and out, mainly out. pulled the power several times to no avail.
any thoughts?
Is this for all devices or just specific ones? Can you provide the logs from when it happens please?
every device connected to the r3 doesn’t work. i now have plugged some devices into my modem  which work perfectly.
how do i get the logs please
got the logs
Fri Jan  2 22:04:32 2026 daemon.err miniupnpd[21442]: sendto(udp_notify=6, 192.168.77.1): Operation not permitted
Fri Jan  2 22:04:32 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:04:32 2026 user.notice hotplug: Device:eth0, Interface:wan6, Action:ifup
Fri Jan  2 22:04:32 2026 user.notice lolnet: setup eth0 wan6
Fri Jan  2 22:04:32 2026 daemon.notice miniupnpd[21442]: shutting down MiniUPnPd
Fri Jan  2 22:04:34 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:04:34 2026 daemon.err miniupnpd[22033]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:04:34 2026 daemon.notice miniupnpd[22033]: HTTP listening on port 5000
Fri Jan  2 22:04:34 2026 daemon.warn miniupnpd[22033]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:04:34 2026 daemon.notice miniupnpd[22033]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:04:34 2026 daemon.err miniupnpd[22033]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:04:46 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=161, from=WorkAtHome, to=VPN
Fri Jan  2 22:04:46 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=159, from=WorkAtHome, to=VPN
Fri Jan  2 22:05:50 2026 daemon.notice netifd: Network device 'eth0' link is down
Fri Jan  2 22:05:50 2026 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Jan  2 22:05:50 2026 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Fri Jan  2 22:05:50 2026 daemon.notice netifd: wan6 (19630): Command failed: Permission denied
Fri Jan  2 22:05:50 2026 daemon.notice netifd: wan (19631): udhcpc: received SIGTERM
Fri Jan  2 22:05:50 2026 daemon.notice netifd: wan (19631): udhcpc: unicasting a release of 192.168.1.100 to 192.168.1.1
Fri Jan  2 22:05:50 2026 daemon.notice netifd: wan (19631): udhcpc: sending release
Fri Jan  2 22:05:50 2026 daemon.notice netifd: wan (19631): udhcpc: entering released state
Fri Jan  2 22:05:50 2026 daemon.notice netifd: wan (19631): Command failed: Permission denied
Fri Jan  2 22:05:50 2026 daemon.notice netifd: Interface 'wan' is now down
Fri Jan  2 22:05:50 2026 daemon.err miniupnpd[22033]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Fri Jan  2 22:05:50 2026 daemon.err miniupnpd[22033]: Failed to get IP for interface eth0
Fri Jan  2 22:05:50 2026 daemon.warn miniupnpd[22033]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Fri Jan  2 22:05:50 2026 daemon.err miniupnpd[22033]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:05:50 2026 user.notice firewall: Reloading firewall due to ifdown of wan
Fri Jan  2 22:05:50 2026 daemon.notice netifd: Interface 'wan6' is now down
Fri Jan  2 22:05:50 2026 daemon.warn dnsmasq[7888]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Fri Jan  2 22:05:51 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:05:51 2026 user.notice hotplug: Device:, Interface:wan, Action:ifdown
Fri Jan  2 22:05:51 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency cleanup
Fri Jan  2 22:05:51 2026 user.notice hotplug: Device:, Interface:wan6, Action:ifdown
Fri Jan  2 22:05:52 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 9 #res 9, flushing
Fri Jan  2 22:05:52 2026 user.warn com.netdumasoftware.autoadmin: Some of the cleanup calls for com.netdumasoftware.overwatch failed.
Fri Jan  2 22:05:53 2026 daemon.notice netifd: Network device 'eth0' link is up
Fri Jan  2 22:05:53 2026 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Jan  2 22:05:53 2026 daemon.notice netifd: Interface 'wan' is setting up now
Fri Jan  2 22:05:53 2026 daemon.notice netifd: Interface 'wan6' has link connectivity
Fri Jan  2 22:05:53 2026 daemon.notice netifd: Interface 'wan6' is setting up now
Fri Jan  2 22:05:53 2026 daemon.notice netifd: wan (23452): udhcpc: started, v1.31.1
Fri Jan  2 22:05:53 2026 daemon.notice netifd: wan (23452): udhcpc: sending discover
Fri Jan  2 22:05:54 2026 daemon.notice netifd: wan (23452): udhcpc: sending select for 192.168.1.100
Fri Jan  2 22:05:54 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:05:54 2026 daemon.notice netifd: wan (23452): udhcpc: lease of 192.168.1.100 obtained, lease time 4294967295
Fri Jan  2 22:05:54 2026 daemon.err miniupnpd[22033]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:05:54 2026 daemon.notice netifd: Interface 'wan' is now up
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:05:54 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:05:55 2026 user.notice hotplug: Cur Public IP: 80.189.180.29
Fri Jan  2 22:05:55 2026 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Fri Jan  2 22:05:55 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:05:55 2026 user.notice hotplug: Device:eth0, Interface:wan, Action:ifup
Fri Jan  2 22:05:55 2026 user.notice lolnet: setup eth0 wan
Fri Jan  2 22:05:56 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 53916e50: time went backwards!
Fri Jan  2 22:05:57 2026 daemon.notice netifd: Interface 'wan6' is now up
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:05:57 2026 daemon.info dnsmasq[7888]: using nameserver fe80::1%eth0#53
Fri Jan  2 22:05:57 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 49e2106: time went backwards!
Fri Jan  2 22:06:00 2026 user.notice overwatch-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:06:01 2026 user.warn overwatch: [0;33m[WARNING]: [0mUnknown netmask; IPv4 broadcast filters will fail to compile.
Fri Jan  2 22:06:01 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 0 #res 0, flushing
Fri Jan  2 22:06:02 2026 user.info overwatch: [0;36m[INFO]: [0mReserved bit=28
Fri Jan  2 22:06:02 2026 user.info overwatch: [0;36m[INFO]: [0mReserved nfqueue=3
Fri Jan  2 22:06:02 2026 user.info Smart QoS: Shutting down daemon
Fri Jan  2 22:06:02 2026 user.warn overwatch: [0;31m[ERROR]: [0mdlopen(): geolatency.so: cannot open shared object file: No such file or directory
Fri Jan  2 22:06:02 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency init
Fri Jan  2 22:06:06 2026 user.notice smartqos-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:06:06 2026 user.info Smart QoS: Starting daemon
Fri Jan  2 22:06:07 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end sq-sched, #cstack 0 #res 0, flushing
Fri Jan  2 22:06:07 2026 daemon.notice miniupnpd[22033]: shutting down MiniUPnPd
Fri Jan  2 22:06:08 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:06:08 2026 daemon.err miniupnpd[25237]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:06:08 2026 daemon.notice miniupnpd[25237]: HTTP listening on port 5000
Fri Jan  2 22:06:08 2026 user.notice firewall: Reloading firewall due to ifup of wan6 (eth0)
Fri Jan  2 22:06:08 2026 daemon.warn miniupnpd[25237]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:06:08 2026 daemon.notice miniupnpd[25237]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:06:08 2026 daemon.err miniupnpd[25237]: PCPSendUnsolicitedAnnounce() sendto(): Operation not permitted
Fri Jan  2 22:06:08 2026 daemon.err miniupnpd[25237]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:06:08 2026 daemon.err miniupnpd[25237]: sendto(udp_notify=6, 192.168.77.1): Operation not permitted
Fri Jan  2 22:06:09 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:06:09 2026 user.notice hotplug: Device:eth0, Interface:wan6, Action:ifup
Fri Jan  2 22:06:09 2026 user.notice lolnet: setup eth0 wan6
Fri Jan  2 22:06:09 2026 daemon.notice miniupnpd[25237]: shutting down MiniUPnPd
Fri Jan  2 22:06:11 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:06:11 2026 daemon.err miniupnpd[25822]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:06:11 2026 daemon.notice miniupnpd[25822]: HTTP listening on port 5000
Fri Jan  2 22:06:11 2026 daemon.warn miniupnpd[25822]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:06:11 2026 daemon.notice miniupnpd[25822]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:06:11 2026 daemon.err miniupnpd[25822]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:06:17 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=161, from=WorkAtHome, to=VPN
Fri Jan  2 22:06:17 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=159, from=WorkAtHome, to=VPN
Fri Jan  2 22:07:42 2026 daemon.notice netifd: Network device 'eth0' link is down
Fri Jan  2 22:07:42 2026 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Jan  2 22:07:42 2026 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Fri Jan  2 22:07:42 2026 daemon.notice netifd: wan6 (23451): Command failed: Permission denied
Fri Jan  2 22:07:42 2026 daemon.notice netifd: wan (23452): udhcpc: received SIGTERM
Fri Jan  2 22:07:42 2026 daemon.notice netifd: wan (23452): udhcpc: unicasting a release of 192.168.1.100 to 192.168.1.1
Fri Jan  2 22:07:42 2026 daemon.notice netifd: wan (23452): udhcpc: sending release
Fri Jan  2 22:07:42 2026 daemon.notice netifd: wan (23452): udhcpc: entering released state
Fri Jan  2 22:07:42 2026 daemon.notice netifd: wan (23452): Command failed: Permission denied
Fri Jan  2 22:07:42 2026 daemon.notice netifd: Interface 'wan' is now down
Fri Jan  2 22:07:42 2026 daemon.err miniupnpd[25822]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Fri Jan  2 22:07:42 2026 daemon.err miniupnpd[25822]: Failed to get IP for interface eth0
Fri Jan  2 22:07:42 2026 daemon.warn miniupnpd[25822]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Fri Jan  2 22:07:42 2026 daemon.err miniupnpd[25822]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:07:42 2026 daemon.warn dnsmasq[7888]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Fri Jan  2 22:07:42 2026 user.notice firewall: Reloading firewall due to ifdown of wan
Fri Jan  2 22:07:42 2026 daemon.err odhcp6c[23451]: Failed to send SOLICIT message to ff02::1:2 (Operation not permitted)
Fri Jan  2 22:07:42 2026 daemon.notice netifd: Interface 'wan6' is now down
Fri Jan  2 22:07:42 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:07:42 2026 user.notice hotplug: Device:, Interface:wan, Action:ifdown
Fri Jan  2 22:07:43 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency cleanup
Fri Jan  2 22:07:43 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:07:43 2026 user.notice hotplug: Device:, Interface:wan6, Action:ifdown
Fri Jan  2 22:07:44 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 9 #res 9, flushing
Fri Jan  2 22:07:44 2026 user.warn com.netdumasoftware.autoadmin: Some of the cleanup calls for com.netdumasoftware.overwatch failed.
Fri Jan  2 22:07:45 2026 daemon.notice netifd: Network device 'eth0' link is up
Fri Jan  2 22:07:45 2026 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Jan  2 22:07:45 2026 daemon.notice netifd: Interface 'wan' is setting up now
Fri Jan  2 22:07:45 2026 daemon.notice netifd: Interface 'wan6' has link connectivity
Fri Jan  2 22:07:45 2026 daemon.notice netifd: Interface 'wan6' is setting up now
Fri Jan  2 22:07:45 2026 daemon.notice netifd: wan (27236): udhcpc: started, v1.31.1
Fri Jan  2 22:07:45 2026 daemon.notice netifd: wan (27236): udhcpc: sending discover
Fri Jan  2 22:07:46 2026 daemon.notice netifd: wan (27236): udhcpc: sending select for 192.168.1.100
Fri Jan  2 22:07:46 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:07:46 2026 daemon.notice netifd: wan (27236): udhcpc: lease of 192.168.1.100 obtained, lease time 4294967295
Fri Jan  2 22:07:46 2026 daemon.err miniupnpd[25822]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:07:46 2026 daemon.notice netifd: Interface 'wan' is now up
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:07:46 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:07:47 2026 user.notice hotplug: Cur Public IP: 80.189.180.29
Fri Jan  2 22:07:47 2026 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Fri Jan  2 22:07:48 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 7078ac46: time went backwards!
Fri Jan  2 22:07:48 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:07:48 2026 user.notice hotplug: Device:eth0, Interface:wan, Action:ifup
Fri Jan  2 22:07:48 2026 user.notice lolnet: setup eth0 wan
Fri Jan  2 22:07:48 2026 daemon.notice netifd: Interface 'wan6' is now up
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:07:48 2026 daemon.info dnsmasq[7888]: using nameserver fe80::1%eth0#53
Fri Jan  2 22:07:48 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 1a93b8e1: time went backwards!
Fri Jan  2 22:07:53 2026 user.notice overwatch-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:07:53 2026 user.warn overwatch: [0;33m[WARNING]: [0mUnknown netmask; IPv4 broadcast filters will fail to compile.
Fri Jan  2 22:07:53 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 0 #res 0, flushing
Fri Jan  2 22:07:55 2026 user.info overwatch: [0;36m[INFO]: [0mReserved bit=28
Fri Jan  2 22:07:55 2026 user.info overwatch: [0;36m[INFO]: [0mReserved nfqueue=3
Fri Jan  2 22:07:55 2026 user.info Smart QoS: Shutting down daemon
Fri Jan  2 22:07:55 2026 user.warn overwatch: [0;31m[ERROR]: [0mdlopen(): geolatency.so: cannot open shared object file: No such file or directory
Fri Jan  2 22:07:55 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency init
Fri Jan  2 22:07:56 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=161, from=WorkAtHome, to=VPN
Fri Jan  2 22:07:56 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=159, from=WorkAtHome, to=VPN
Fri Jan  2 22:07:58 2026 user.notice smartqos-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:07:59 2026 user.info Smart QoS: Starting daemon
Fri Jan  2 22:08:00 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end sq-sched, #cstack 0 #res 0, flushing
Fri Jan  2 22:08:00 2026 daemon.notice miniupnpd[25822]: shutting down MiniUPnPd
Fri Jan  2 22:08:00 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:08:00 2026 daemon.err miniupnpd[28983]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:08:00 2026 daemon.notice miniupnpd[28983]: HTTP listening on port 5000
Fri Jan  2 22:08:00 2026 daemon.warn miniupnpd[28983]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:08:00 2026 user.notice firewall: Reloading firewall due to ifup of wan6 (eth0)
Fri Jan  2 22:08:00 2026 daemon.notice miniupnpd[28983]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:08:00 2026 daemon.err miniupnpd[28983]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:08:01 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:08:01 2026 user.notice hotplug: Device:eth0, Interface:wan6, Action:ifup
Fri Jan  2 22:08:01 2026 user.notice lolnet: setup eth0 wan6
Fri Jan  2 22:08:01 2026 daemon.notice miniupnpd[28983]: shutting down MiniUPnPd
Fri Jan  2 22:08:02 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:08:02 2026 daemon.err miniupnpd[29532]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:08:02 2026 daemon.notice miniupnpd[29532]: HTTP listening on port 5000
Fri Jan  2 22:08:02 2026 daemon.warn miniupnpd[29532]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:08:02 2026 daemon.notice miniupnpd[29532]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:08:02 2026 daemon.err miniupnpd[29532]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:09:20 2026 daemon.notice netifd: Network device 'eth0' link is down
Fri Jan  2 22:09:20 2026 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Jan  2 22:09:20 2026 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Fri Jan  2 22:09:20 2026 daemon.notice netifd: wan6 (27234): Command failed: Permission denied
Fri Jan  2 22:09:20 2026 daemon.notice netifd: wan (27236): udhcpc: received SIGTERM
Fri Jan  2 22:09:20 2026 daemon.notice netifd: wan (27236): udhcpc: unicasting a release of 192.168.1.100 to 192.168.1.1
Fri Jan  2 22:09:20 2026 daemon.notice netifd: wan (27236): udhcpc: sending release
Fri Jan  2 22:09:20 2026 daemon.notice netifd: wan (27236): udhcpc: entering released state
Fri Jan  2 22:09:20 2026 daemon.notice netifd: wan (27236): Command failed: Permission denied
Fri Jan  2 22:09:20 2026 daemon.notice netifd: Interface 'wan' is now down
Fri Jan  2 22:09:20 2026 daemon.err miniupnpd[29532]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Fri Jan  2 22:09:20 2026 daemon.err miniupnpd[29532]: Failed to get IP for interface eth0
Fri Jan  2 22:09:20 2026 daemon.warn miniupnpd[29532]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Fri Jan  2 22:09:20 2026 daemon.err miniupnpd[29532]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:09:20 2026 user.notice firewall: Reloading firewall due to ifdown of wan
Fri Jan  2 22:09:20 2026 daemon.warn dnsmasq[7888]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Fri Jan  2 22:09:20 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:09:20 2026 user.notice hotplug: Device:, Interface:wan, Action:ifdown
Fri Jan  2 22:09:20 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency cleanup
Fri Jan  2 22:09:21 2026 daemon.notice netifd: Interface 'wan6' is now down
Fri Jan  2 22:09:21 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:09:21 2026 user.notice hotplug: Device:, Interface:wan6, Action:ifdown
Fri Jan  2 22:09:21 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 9 #res 9, flushing
Fri Jan  2 22:09:22 2026 user.warn com.netdumasoftware.autoadmin: Some of the cleanup calls for com.netdumasoftware.overwatch failed.
Fri Jan  2 22:09:23 2026 daemon.notice netifd: Network device 'eth0' link is up
Fri Jan  2 22:09:23 2026 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Jan  2 22:09:23 2026 daemon.notice netifd: Interface 'wan' is setting up now
Fri Jan  2 22:09:23 2026 daemon.notice netifd: Interface 'wan6' has link connectivity
Fri Jan  2 22:09:23 2026 daemon.notice netifd: Interface 'wan6' is setting up now
Fri Jan  2 22:09:23 2026 daemon.notice netifd: wan (30526): udhcpc: started, v1.31.1
Fri Jan  2 22:09:23 2026 daemon.notice netifd: wan (30526): udhcpc: sending discover
Fri Jan  2 22:09:23 2026 daemon.notice netifd: wan (30526): udhcpc: sending select for 192.168.1.100
Fri Jan  2 22:09:24 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:09:24 2026 daemon.notice netifd: wan (30526): udhcpc: lease of 192.168.1.100 obtained, lease time 4294967295
Fri Jan  2 22:09:24 2026 daemon.err miniupnpd[29532]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:09:24 2026 daemon.notice netifd: Interface 'wan' is now up
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:09:24 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:09:24 2026 user.notice hotplug: Cur Public IP: 80.189.180.29
Fri Jan  2 22:09:24 2026 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Fri Jan  2 22:09:25 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:09:25 2026 user.notice hotplug: Device:eth0, Interface:wan, Action:ifup
Fri Jan  2 22:09:25 2026 user.notice lolnet: setup eth0 wan
Fri Jan  2 22:09:26 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:09:26 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 5971BC5137808698
Fri Jan  2 22:09:26 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:09:27 2026 daemon.notice netifd: Interface 'wan6' is now up
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:09:27 2026 daemon.info dnsmasq[7888]: using nameserver fe80::1%eth0#53
Fri Jan  2 22:09:28 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:09:28 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:09:28 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 2a5c69ba: time went backwards!
Fri Jan  2 22:09:30 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:09:30 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:09:30 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:09:30 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:09:30 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:09:30 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:09:30 2026 user.notice overwatch-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:09:31 2026 user.info Smart QoS: Shutting down daemon
Fri Jan  2 22:09:32 2026 user.warn overwatch: [0;33m[WARNING]: [0mUnknown netmask; IPv4 broadcast filters will fail to compile.
Fri Jan  2 22:09:32 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 0 #res 0, flushing
Fri Jan  2 22:09:33 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct e4db5c03: time went backwards!
Fri Jan  2 22:09:33 2026 user.info overwatch: [0;36m[INFO]: [0mReserved bit=28
Fri Jan  2 22:09:33 2026 user.info overwatch: [0;36m[INFO]: [0mReserved nfqueue=3
Fri Jan  2 22:09:33 2026 user.warn overwatch: [0;31m[ERROR]: [0mdlopen(): geolatency.so: cannot open shared object file: No such file or directory
Fri Jan  2 22:09:33 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency init
Fri Jan  2 22:09:35 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 80a27098: time went backwards!
Fri Jan  2 22:09:35 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=161, from=WorkAtHome, to=VPN
Fri Jan  2 22:09:35 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=159, from=WorkAtHome, to=VPN
Fri Jan  2 22:09:35 2026 user.notice smartqos-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:09:36 2026 user.info Smart QoS: Starting daemon
Fri Jan  2 22:09:37 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end sq-sched, #cstack 0 #res 0, flushing
Fri Jan  2 22:09:37 2026 daemon.notice miniupnpd[29532]: shutting down MiniUPnPd
Fri Jan  2 22:09:38 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 2ca509a2: time went backwards!
Fri Jan  2 22:09:38 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:09:38 2026 daemon.err miniupnpd[32513]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:09:38 2026 daemon.notice miniupnpd[32513]: HTTP listening on port 5000
Fri Jan  2 22:09:38 2026 user.notice firewall: Reloading firewall due to ifup of wan6 (eth0)
Fri Jan  2 22:09:38 2026 daemon.warn miniupnpd[32513]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:09:38 2026 daemon.notice miniupnpd[32513]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:09:38 2026 daemon.err miniupnpd[32513]: PCPSendUnsolicitedAnnounce() sendto(): Operation not permitted
Fri Jan  2 22:09:38 2026 daemon.err miniupnpd[32513]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:09:38 2026 daemon.err miniupnpd[32513]: sendto(udp_notify=6, 192.168.77.1): Operation not permitted
Fri Jan  2 22:09:39 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct ec9753fa: time went backwards!
Fri Jan  2 22:09:39 2026 user.warn overwatch: [0;33m[WARNING]: [0mprepromoted packet missing mark
Fri Jan  2 22:09:39 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:09:39 2026 user.notice hotplug: Device:eth0, Interface:wan6, Action:ifup
Fri Jan  2 22:09:39 2026 user.notice lolnet: setup eth0 wan6
Fri Jan  2 22:09:39 2026 daemon.notice miniupnpd[32513]: shutting down MiniUPnPd
Fri Jan  2 22:09:40 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d0d4fd79: time went backwards!
Fri Jan  2 22:09:41 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:09:41 2026 daemon.err miniupnpd[641]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:09:41 2026 daemon.notice miniupnpd[641]: HTTP listening on port 5000
Fri Jan  2 22:09:41 2026 daemon.warn miniupnpd[641]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:09:41 2026 daemon.notice miniupnpd[641]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:09:41 2026 daemon.err miniupnpd[641]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:09:53 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 7400c455: time went backwards!
Fri Jan  2 22:09:55 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct c7b4999b: time went backwards!
Fri Jan  2 22:10:16 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct b3557b65: time went backwards!
Fri Jan  2 22:10:16 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 8d4ac8db: time went backwards!
Fri Jan  2 22:10:21 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 3db781b2: time went backwards!
Fri Jan  2 22:12:12 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct eb0623cb: time went backwards!
Fri Jan  2 22:12:13 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:12:15 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:12:16 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 5971BC5137808698
Fri Jan  2 22:12:16 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:12:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:18 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:18 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:19 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:12:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:22 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:22 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:22 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:12:22 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:12:22 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:12:22 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:12:23 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:12:27 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:12:28 2026 daemon.err cli.lua[4273]: RTNETLINK answers: File exists
Fri Jan  2 22:12:29 2026 user.warn com.netdumasoftware.devicemanager: Address family for hostname not supported
Fri Jan  2 22:12:30 2026 user.warn com.netdumasoftware.devicemanager: Address family for hostname not supported
Fri Jan  2 22:12:31 2026 user.warn com.netdumasoftware.devicemanager: Address family for hostname not supported
Fri Jan  2 22:12:32 2026 user.warn com.netdumasoftware.devicemanager: Address family for hostname not supported
Fri Jan  2 22:12:33 2026 user.warn com.netdumasoftware.devicemanager: Address family for hostname not supported
Fri Jan  2 22:12:34 2026 daemon.err cli.lua[4273]: RTNETLINK answers: No such process
Fri Jan  2 22:12:41 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 6550649a: time went backwards!
Fri Jan  2 22:12:42 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 6550649a: time went backwards!
Fri Jan  2 22:12:42 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 9c82054e: time went backwards!
Fri Jan  2 22:13:01 2026 daemon.err cli.lua[4273]: goto outTLS hook failed
Fri Jan  2 22:13:01 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct bfab662a: time went backwards!
Fri Jan  2 22:13:01 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d8f5eba9: time went backwards!
Fri Jan  2 22:13:18 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 3cc9cbbc: time went backwards!
Fri Jan  2 22:13:55 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct bfab662a: time went backwards!
Fri Jan  2 22:13:55 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct f8c6d6d: time went backwards!
Fri Jan  2 22:13:58 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 69641722: time went backwards!
Fri Jan  2 22:13:59 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:13:59 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 5971BC5137808698
Fri Jan  2 22:13:59 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:13:59 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: disassociated
Fri Jan  2 22:13:59 2026 daemon.notice hostapd: wl0: AP-STA-DISCONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:06 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct db385d3d: time went backwards!
Fri Jan  2 22:14:06 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d82e5a10: time went backwards!
Fri Jan  2 22:14:09 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 59c01b8c: time went backwards!
Fri Jan  2 22:14:09 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct c7b3a340: time went backwards!
Fri Jan  2 22:14:09 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:14:09 2026 daemon.notice hostapd: wl0: AP-STA-CONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:09 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 24EEA184FB195EFA
Fri Jan  2 22:14:09 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:14:11 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:11 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:14:13 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:14:13 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:14:19 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 4ab8ca85: time went backwards!
Fri Jan  2 22:14:38 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 57122fe0: time went backwards!
Fri Jan  2 22:14:44 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:14:44 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 24EEA184FB195EFA
Fri Jan  2 22:14:44 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:14:45 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 210bb2a9: time went backwards!
Fri Jan  2 22:14:47 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:47 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:49 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:49 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:49 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:49 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:14:49 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:14:49 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:14:51 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:14:51 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:14:51 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:14:51 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:15:00 2026 cron.info crond[2659]: USER root pid 3357 cmd echo 3 > /proc/sys/vm/drop_caches
Fri Jan  2 22:15:06 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:15:10 2026 daemon.notice hostapd: wl0: AP-STA-DISCONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:15 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: deauthenticated due to local deauth request
Fri Jan  2 22:15:15 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d71c9293: time went backwards!
Fri Jan  2 22:15:18 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct b6258622: time went backwards!
Fri Jan  2 22:15:18 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 81980cee: time went backwards!
Fri Jan  2 22:15:18 2026 daemon.err cli.lua[4273]: goto outTLS hook failed
Fri Jan  2 22:15:22 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:15:22 2026 daemon.notice hostapd: wl0: AP-STA-CONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:22 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 820542732F9259D4
Fri Jan  2 22:15:22 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:15:24 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:24 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:26 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:26 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:26 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:26 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:15:27 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:15:27 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:15:31 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct e91e1da7: time went backwards!
Fri Jan  2 22:15:33 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d3bdafd5: time went backwards!
Fri Jan  2 22:15:34 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 3eaa4f0: time went backwards!
Fri Jan  2 22:15:38 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct b84a14dd: time went backwards!
Fri Jan  2 22:15:42 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 796d5f86: time went backwards!
Fri Jan  2 22:15:43 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 796d5f86: time went backwards!
Fri Jan  2 22:15:44 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 684e3eb0: time went backwards!
Fri Jan  2 22:15:46 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: disassociated
Fri Jan  2 22:15:46 2026 daemon.notice hostapd: wl0: AP-STA-DISCONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:15:46 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d1a662d8: time went backwards!
Fri Jan  2 22:15:47 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: disassociated
Fri Jan  2 22:15:51 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct a6a36ee: time went backwards!
Fri Jan  2 22:15:52 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct a6a36ee: time went backwards!
Fri Jan  2 22:15:53 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 9f56c086: time went backwards!
Fri Jan  2 22:15:56 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 9a3c9a4e: time went backwards!
Fri Jan  2 22:15:57 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 9a3c9a4e: time went backwards!
Fri Jan  2 22:16:00 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 3b581b68: time went backwards!
Fri Jan  2 22:16:07 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 1fdd95ec: time went backwards!
Fri Jan  2 22:16:09 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 6655e4fa: time went backwards!
Fri Jan  2 22:16:11 2026 user.warn overwatch: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied
Fri Jan  2 22:16:11 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct a182055b: time went backwards!
Fri Jan  2 22:16:11 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 31a53976: time went backwards!
Fri Jan  2 22:16:13 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:16:13 2026 daemon.notice hostapd: wl0: AP-STA-CONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:13 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 69DA2D800676851E
Fri Jan  2 22:16:13 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:16:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:14 2026 daemon.err cli.lua[4273]: goto outTLS hook failed
Fri Jan  2 22:16:15 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:15 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:17 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:17 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:19 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:19 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:19 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:19 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:16:19 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:16:19 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:16:25 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:16:25 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 69DA2D800676851E
Fri Jan  2 22:16:25 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:16:27 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:27 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:29 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:29 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:29 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:16:29 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:16:29 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:16:29 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:16:40 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct e648b3b1: time went backwards!
Fri Jan  2 22:16:40 2026 user.warn overwatch: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied
Fri Jan  2 22:16:41 2026 user.warn overwatch: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied
Fri Jan  2 22:16:43 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 76541520: time went backwards!
Fri Jan  2 22:16:43 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct e31d2bbe: time went backwards!
Fri Jan  2 22:16:43 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct f72fa993: time went backwards!
Fri Jan  2 22:16:59 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d89861cd: time went backwards!
Fri Jan  2 22:16:59 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 207ddd07: time went backwards!
Fri Jan  2 22:17:09 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct d89861cd: time went backwards!
Fri Jan  2 22:17:10 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 7f29a226: time went backwards!
Fri Jan  2 22:17:12 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: disassociated
Fri Jan  2 22:17:12 2026 daemon.notice hostapd: wl0: AP-STA-DISCONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:14 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct bb8c38e8: time went backwards!
Fri Jan  2 22:17:14 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:17:14 2026 daemon.notice hostapd: wl0: AP-STA-CONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:14 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 009BC204D4E7CC74
Fri Jan  2 22:17:14 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:17:15 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:15 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:17:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:17:16 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:17:17 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:17:17 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:17:23 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 5b431b47: time went backwards!
Fri Jan  2 22:17:26 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 96eb3e9: time went backwards!
Fri Jan  2 22:17:53 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:17:58 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct e8232434: time went backwards!
Fri Jan  2 22:17:59 2026 daemon.err cli.lua[4273]: goto outTLS hook failed
Fri Jan  2 22:17:59 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 64a5a62: time went backwards!
Fri Jan  2 22:18:02 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 27363b18: time went backwards!
Fri Jan  2 22:18:09 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 64a5a62: time went backwards!
Fri Jan  2 22:18:09 2026 daemon.err cli.lua[4273]: [0;33m[WARNING]: [0mct 13f56ff: time went backwards!
Fri Jan  2 22:18:18 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:18:18 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 009BC204D4E7CC74
Fri Jan  2 22:18:18 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:18:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:22 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:22 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:23 2026 daemon.notice netifd: Network device 'eth0' link is down
Fri Jan  2 22:18:23 2026 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Jan  2 22:18:23 2026 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Fri Jan  2 22:18:23 2026 daemon.notice netifd: wan6 (30525): Command failed: Permission denied
Fri Jan  2 22:18:23 2026 daemon.notice netifd: wan (30526): udhcpc: received SIGTERM
Fri Jan  2 22:18:23 2026 daemon.notice netifd: wan (30526): udhcpc: unicasting a release of 192.168.1.100 to 192.168.1.1
Fri Jan  2 22:18:23 2026 daemon.notice netifd: wan (30526): udhcpc: sending release
Fri Jan  2 22:18:23 2026 daemon.notice netifd: wan (30526): udhcpc: entering released state
Fri Jan  2 22:18:23 2026 daemon.notice netifd: wan (30526): Command failed: Permission denied
Fri Jan  2 22:18:24 2026 daemon.notice netifd: Interface 'wan' is now down
Fri Jan  2 22:18:24 2026 daemon.err miniupnpd[641]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Fri Jan  2 22:18:24 2026 daemon.err miniupnpd[641]: Failed to get IP for interface eth0
Fri Jan  2 22:18:24 2026 daemon.warn miniupnpd[641]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Fri Jan  2 22:18:24 2026 daemon.warn dnsmasq[7888]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Fri Jan  2 22:18:24 2026 daemon.err miniupnpd[641]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:18:24 2026 user.notice firewall: Reloading firewall due to ifdown of wan
Fri Jan  2 22:18:24 2026 daemon.notice netifd: Interface 'wan6' is now down
Fri Jan  2 22:18:24 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:18:24 2026 user.notice hotplug: Device:, Interface:wan, Action:ifdown
Fri Jan  2 22:18:24 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:24 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:24 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:18:24 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:18:24 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:18:24 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:18:25 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency cleanup
Fri Jan  2 22:18:25 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:18:25 2026 user.notice hotplug: Device:, Interface:wan6, Action:ifdown
Fri Jan  2 22:18:26 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 9 #res 9, flushing
Fri Jan  2 22:18:26 2026 user.warn com.netdumasoftware.autoadmin: Some of the cleanup calls for com.netdumasoftware.overwatch failed.
Fri Jan  2 22:18:27 2026 daemon.notice netifd: Network device 'eth0' link is up
Fri Jan  2 22:18:27 2026 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Jan  2 22:18:27 2026 daemon.notice netifd: Interface 'wan' is setting up now
Fri Jan  2 22:18:27 2026 daemon.notice netifd: Interface 'wan6' has link connectivity
Fri Jan  2 22:18:27 2026 daemon.notice netifd: Interface 'wan6' is setting up now
Fri Jan  2 22:18:27 2026 daemon.notice netifd: wan (5633): udhcpc: started, v1.31.1
Fri Jan  2 22:18:27 2026 daemon.notice netifd: wan (5633): udhcpc: sending discover
Fri Jan  2 22:18:27 2026 daemon.notice netifd: wan (5633): udhcpc: sending select for 192.168.1.100
Fri Jan  2 22:18:28 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:18:28 2026 daemon.notice netifd: wan (5633): udhcpc: lease of 192.168.1.100 obtained, lease time 4294967295
Fri Jan  2 22:18:28 2026 daemon.err miniupnpd[641]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:18:28 2026 daemon.notice netifd: Interface 'wan' is now up
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:18:28 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:18:28 2026 user.notice hotplug: Cur Public IP: 80.189.180.29
Fri Jan  2 22:18:28 2026 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Fri Jan  2 22:18:29 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:18:29 2026 user.notice hotplug: Device:eth0, Interface:wan, Action:ifup
Fri Jan  2 22:18:29 2026 user.notice lolnet: setup eth0 wan
Fri Jan  2 22:18:31 2026 daemon.notice netifd: Interface 'wan6' is now up
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using local addresses only for domain test
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using local addresses only for domain onion
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using local addresses only for domain localhost
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using local addresses only for domain invalid
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using local addresses only for domain bind
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using local addresses only for domain lan
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.8.8#53
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using nameserver 8.8.4.4#53
Fri Jan  2 22:18:31 2026 daemon.info dnsmasq[7888]: using nameserver fe80::1%eth0#53
Fri Jan  2 22:18:34 2026 user.notice overwatch-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:18:34 2026 user.warn overwatch: [0;33m[WARNING]: [0mUnknown netmask; IPv4 broadcast filters will fail to compile.
Fri Jan  2 22:18:35 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end com.netdumasoftware.overwatch, #cstack 0 #res 0, flushing
Fri Jan  2 22:18:36 2026 user.info overwatch: [0;36m[INFO]: [0mReserved bit=28
Fri Jan  2 22:18:36 2026 user.info overwatch: [0;36m[INFO]: [0mReserved nfqueue=3
Fri Jan  2 22:18:36 2026 user.info Smart QoS: Shutting down daemon
Fri Jan  2 22:18:36 2026 user.warn overwatch: [0;31m[ERROR]: [0mdlopen(): geolatency.so: cannot open shared object file: No such file or directory
Fri Jan  2 22:18:36 2026 user.info overwatch: [0;36m[INFO]: [0mGeolatency init
Fri Jan  2 22:18:39 2026 user.notice smartqos-initd:: Waiting for com.netdumasoftware.devicemanager
Fri Jan  2 22:18:40 2026 user.info Smart QoS: Starting daemon
Fri Jan  2 22:18:41 2026 user.info com.netdumasoftware.autoadmin: ---- rapp end sq-sched, #cstack 0 #res 0, flushing
Fri Jan  2 22:18:41 2026 daemon.notice miniupnpd[641]: shutting down MiniUPnPd
Fri Jan  2 22:18:42 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:18:42 2026 daemon.err miniupnpd[7424]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:18:42 2026 daemon.notice miniupnpd[7424]: HTTP listening on port 5000
Fri Jan  2 22:18:42 2026 user.notice firewall: Reloading firewall due to ifup of wan6 (eth0)
Fri Jan  2 22:18:42 2026 daemon.warn miniupnpd[7424]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:18:42 2026 daemon.notice miniupnpd[7424]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:18:42 2026 daemon.err miniupnpd[7424]: PCPSendUnsolicitedAnnounce() sendto(): Operation not permitted
Fri Jan  2 22:18:42 2026 daemon.err miniupnpd[7424]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:18:42 2026 daemon.err miniupnpd[7424]: sendto(udp_notify=6, 192.168.77.1): Operation not permitted
Fri Jan  2 22:18:43 2026 user.notice hotplug: enter 25-routermac script for runner runtime config
Fri Jan  2 22:18:43 2026 user.notice hotplug: Device:eth0, Interface:wan6, Action:ifup
Fri Jan  2 22:18:43 2026 user.notice lolnet: setup eth0 wan6
Fri Jan  2 22:18:43 2026 daemon.notice miniupnpd[7424]: shutting down MiniUPnPd
Fri Jan  2 22:18:44 2026 user.info miniupnpd: notify script set to /usr/bin/nd_upnp_hook.sh
Fri Jan  2 22:18:44 2026 daemon.err miniupnpd[7980]: could not open lease file: /var/run/miniupnpd.leases
Fri Jan  2 22:18:44 2026 daemon.notice miniupnpd[7980]: HTTP listening on port 5000
Fri Jan  2 22:18:44 2026 daemon.warn miniupnpd[7980]: no HTTP IPv6 address, disabling IPv6
Fri Jan  2 22:18:44 2026 daemon.notice miniupnpd[7980]: Listening for NAT-PMP/PCP traffic on port 5351
Fri Jan  2 22:18:44 2026 daemon.err miniupnpd[7980]: PCPSendUnsolicitedAnnounce() IPv6 sendto(): Bad file descriptor
Fri Jan  2 22:19:09 2026 daemon.info hostapd: wl1: STA 74:a6:cd:a8:78:80 IEEE 802.11: associated
Fri Jan  2 22:19:09 2026 daemon.notice hostapd: wl1: AP-STA-CONNECTED 74:a6:cd:a8:78:80
Fri Jan  2 22:19:09 2026 daemon.info hostapd: wl1: STA 74:a6:cd:a8:78:80 RADIUS: starting accounting session 322FDCF3F278A488
Fri Jan  2 22:19:09 2026 daemon.info hostapd: wl1: STA 74:a6:cd:a8:78:80 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:19:09 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:19:10 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=161, from=WorkAtHome, to=VPN
Fri Jan  2 22:19:10 2026 user.warn overwatch: [0;33m[WARNING]: [0mChanging category of appid=159, from=WorkAtHome, to=VPN
Fri Jan  2 22:19:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 74:a6:cd:a8:78:80
Fri Jan  2 22:19:13 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.127 74:a6:cd:a8:78:80
Fri Jan  2 22:19:14 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.127 74:a6:cd:a8:78:80
Fri Jan  2 22:19:14 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.127 74:a6:cd:a8:78:80 MacBook-Air
Fri Jan  2 22:19:14 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:19:14 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:19:14 2026 user.info com.netdumasoftware.neighwatch: DHCP new lease allocated.
Fri Jan  2 22:19:14 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:19:18 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:20:03 2026 daemon.info hostapd: wl1: STA 0a:4e:ea:13:51:ca IEEE 802.11: associated
Fri Jan  2 22:20:03 2026 daemon.notice hostapd: wl1: AP-STA-CONNECTED 0a:4e:ea:13:51:ca
Fri Jan  2 22:20:03 2026 daemon.info hostapd: wl1: STA 0a:4e:ea:13:51:ca RADIUS: starting accounting session 526736775AF9794A
Fri Jan  2 22:20:03 2026 daemon.info hostapd: wl1: STA 0a:4e:ea:13:51:ca WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:20:03 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:20:06 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:20:06 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 009BC204D4E7CC74
Fri Jan  2 22:20:06 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:20:07 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0a:4e:ea:13:51:ca
Fri Jan  2 22:20:07 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.140 0a:4e:ea:13:51:ca
Fri Jan  2 22:20:08 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.140 0a:4e:ea:13:51:ca
Fri Jan  2 22:20:08 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.140 0a:4e:ea:13:51:ca Mac
Fri Jan  2 22:20:08 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:20:08 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:20:08 2026 user.info com.netdumasoftware.neighwatch: DHCP new lease allocated.
Fri Jan  2 22:20:08 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:08 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:08 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:20:10 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:10 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:10 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:10 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:20:10 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:20:10 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:20:13 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:20:14 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: disassociated
Fri Jan  2 22:20:14 2026 daemon.notice hostapd: wl0: AP-STA-DISCONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:16 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:20:16 2026 daemon.notice hostapd: wl0: AP-STA-CONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:16 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 205825855F338BF5
Fri Jan  2 22:20:16 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:20:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:16 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:17 2026 daemon.notice netifd: Network device 'eth1' link is up
Fri Jan  2 22:20:18 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:18 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:20:20 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:20:20 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:20:20 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:20:21 2026 daemon.info hostapd: wl1: STA 74:a6:cd:a8:78:80 IEEE 802.11: disassociated
Fri Jan  2 22:20:21 2026 daemon.notice hostapd: wl1: AP-STA-DISCONNECTED 74:a6:cd:a8:78:80
Fri Jan  2 22:20:22 2026 daemon.info hostapd: wl1: STA 74:a6:cd:a8:78:80 IEEE 802.11: disassociated
Fri Jan  2 22:20:44 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 20:7b:d2:b3:e8:12
Fri Jan  2 22:20:44 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.102 20:7b:d2:b3:e8:12
Fri Jan  2 22:20:45 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.102 20:7b:d2:b3:e8:12
Fri Jan  2 22:20:45 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.102 20:7b:d2:b3:e8:12 MacBook-Air
Fri Jan  2 22:20:45 2026 user.info dpiclass-daemon: DCHP ACK not associated with any particular session.
Fri Jan  2 22:20:45 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:20:45 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:20:45 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:20:45 2026 user.info com.netdumasoftware.neighwatch: DHCP new lease allocated.
Fri Jan  2 22:21:49 2026 user.info com.netdumasoftware.config: Error: a server error occured. No http code received
Fri Jan  2 22:21:50 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.207 00:1c:2b:b2:a4:48
Fri Jan  2 22:21:50 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.207 00:1c:2b:b2:a4:48 myHivehub
Fri Jan  2 22:21:50 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:21:50 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:21:50 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:21:55 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.131 74:ec:b2:70:b9:72
Fri Jan  2 22:21:55 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.131 74:ec:b2:70:b9:72
Fri Jan  2 22:21:55 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:21:55 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:21:55 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:21:55 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.186 cc:f7:35:89:85:3a
Fri Jan  2 22:21:55 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.186 cc:f7:35:89:85:3a
Fri Jan  2 22:22:06 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.203 48:43:dd:07:71:c9
Fri Jan  2 22:22:06 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.203 48:43:dd:07:71:c9
Fri Jan  2 22:22:06 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:22:06 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:22:06 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:22:10 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.229 00:06:78:54:11:78
Fri Jan  2 22:22:10 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.229 00:06:78:54:11:78 Denon-AVC-X4700H
Fri Jan  2 22:22:10 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:22:10 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:22:10 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:22:26 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.104 0c:b8:15:97:1a:88
Fri Jan  2 22:22:26 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.104 0c:b8:15:97:1a:88 Zappi
Fri Jan  2 22:22:26 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:22:26 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:22:27 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:22:27 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:22:53 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.147 c8:2e:18:76:63:64
Fri Jan  2 22:22:53 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.147 c8:2e:18:76:63:64 espressif
Fri Jan  2 22:22:53 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:22:53 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:22:53 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:22:59 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.168 ea:e3:47:06:3c:8c
Fri Jan  2 22:22:59 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.168 ea:e3:47:06:3c:8c
Fri Jan  2 22:22:59 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:22:59 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:22:59 2026 user.info com.netdumasoftware.neighwatch: DHCP new event.
Fri Jan  2 22:23:04 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:23:04 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 205825855F338BF5
Fri Jan  2 22:23:04 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:23:04 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:04 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:06 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:06 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:06 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:06 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:23:06 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:23:06 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:23:07 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:23:12 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:23:16 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:23:24 2026 user.info com.netdumasoftware.config: Error: a server error occured. No http code received
Fri Jan  2 22:23:33 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:23:33 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 205825855F338BF5
Fri Jan  2 22:23:33 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:23:35 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:35 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:37 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:37 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:38 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:38 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:23:38 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:23:38 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:23:40 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:23:40 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:23:40 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:23:40 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:23:40 2026 user.info com.netdumasoftware.config: Error: a server error occured. No http code received
Fri Jan  2 22:23:57 2026 user.info com.netdumasoftware.config: Error: a server error occured. No http code received
Fri Jan  2 22:24:01 2026 daemon.warn odhcpd[2625]: No default route present, overriding ra_lifetime!
Fri Jan  2 22:24:03 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:24:03 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 205825855F338BF5
Fri Jan  2 22:24:03 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:24:05 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:05 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:07 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:07 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:07 2026 daemon.info dnsmasq-dhcp[7888]: DHCPREQUEST(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:07 2026 daemon.info dnsmasq-dhcp[7888]: DHCPACK(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98 chameleon-cad-0ea2f456e298
Fri Jan  2 22:24:07 2026 user.info com.netdumasoftware.neighwatch: DHCP old event.
Fri Jan  2 22:24:07 2026 user.info com.netdumasoftware.neighwatch: DHCP lease change.
Fri Jan  2 22:24:10 2026 user.info com.netdumasoftware.config: Error: a server error occured. No http code received
Fri Jan  2 22:24:23 2026 user.info com.netdumasoftware.config: Error: a server error occured. No http code received
Fri Jan  2 22:24:32 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: disassociated
Fri Jan  2 22:24:32 2026 daemon.notice hostapd: wl0: AP-STA-DISCONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:34 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 IEEE 802.11: associated
Fri Jan  2 22:24:34 2026 daemon.notice hostapd: wl0: AP-STA-CONNECTED 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:34 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 RADIUS: starting accounting session 6C84824615F1DC9C
Fri Jan  2 22:24:34 2026 daemon.info hostapd: wl0: STA 0e:a2:f4:56:e2:98 WPA: pairwise key handshake completed (RSN)
Fri Jan  2 22:24:36 2026 daemon.info dnsmasq-dhcp[7888]: DHCPDISCOVER(br-lan) 0e:a2:f4:56:e2:98
Fri Jan  2 22:24:36 2026 daemon.info dnsmasq-dhcp[7888]: DHCPOFFER(br-lan) 192.168.77.116 0e:a2:f4:56:e2:98
it started today, i changed ISP provider a month ago, all was good until today, i have just disabled ipv6 and rebooted, the problem still persists
