am_8794_ Posted November 17, 2025 Posted November 17, 2025 Ever since my ISP improved their speed and i bought their gaming priotized package my netduma r3 cant handle speed capping like it used to do will there be a update for it in future or any other solution ( my r3 is uptodate - greyed out )
Administrators Netduma Fraser Posted November 17, 2025 Administrators Posted November 17, 2025 I'm not sure what you mean exactly: What are the speeds you pay for? Have you entered the new speeds into the router? What percentages have you set on Congestion Control? Do you have Speed Test bypass enabled? What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g R3 in its DMZ, modem/bridge mode Are ALL devices connected to the R3?
am_8794_ Posted November 19, 2025 Author Posted November 19, 2025 changing point no.4 to disabled worked for me .. my bad , Thankyou
Administrators Netduma Fraser Posted November 20, 2025 Administrators Posted November 20, 2025 Good to hear, thanks for the update!
