TheMW2Ghost Posted November 16, 2025 Posted November 16, 2025 Can we just choose our PC as the device to add for Geo Filtering now or do we still need to set it as a console? I remmeber this was a thing a while back. I want to filter to USA for Black Ops 7, it's been a while since i've done this so just checking if anything has changed? Cheers
Administrators Netduma Fraser Posted November 16, 2025 Administrators Posted November 16, 2025 I would still recommend it, the services can get out of date very quickly so it's just easier for you this way TheMW2Ghost 1
TheMW2Ghost Posted November 16, 2025 Author Posted November 16, 2025 6 minutes ago, Netduma Fraser said: I would still recommend it, the services can get out of date very quickly so it's just easier for you this way Okay, i just select xbox or Playstation (or was it just Games Console?) as the device type here, correct? Then reboot
Administrators Netduma Fraser Posted November 16, 2025 Administrators Posted November 16, 2025 It doesn't matter really it just needs to be one of those, I just say PlayStation as it's the first available console option. You don't need to reboot, just ensure you've set up the Geo-Filter before launching the game client (e.g. Steam etc - make sure it's not just minimized to the System Tray) & game. TheMW2Ghost 1
TheMW2Ghost Posted November 16, 2025 Author Posted November 16, 2025 Thanks, Fraser. I'ts been a while, so I'll pop back here if i something isn't running right if that's okay! Think i've got it set up right tho Netduma Fraser 1
Administrators Netduma Fraser Posted November 16, 2025 Administrators Posted November 16, 2025 Of course, that's what we're here for! TheMW2Ghost 1
TheMW2Ghost Posted November 17, 2025 Author Posted November 17, 2025 I haven't yet tried to filter to another region yet but just wondering, is this normal? Showing my device located all the way down there?
Administrators Netduma Fraser Posted November 17, 2025 Administrators Posted November 17, 2025 That's an anomaly you can ignore that, it does look like the Geo-Filter has been enabled after the game launch? You shouldn't see all servers with a white circle really TheMW2Ghost 1
TheMW2Ghost Posted November 17, 2025 Author Posted November 17, 2025 14 minutes ago, Netduma Fraser said: That's an anomaly you can ignore that, it does look like the Geo-Filter has been enabled after the game launch? You shouldn't see all servers with a white circle really Ok. And yeah, i'm only geetting servers within the circled region so all is good that end. I'll use the custom one tonight to see if it works in putitng me in USA once i've circled those servers
Administrators Netduma Fraser Posted November 17, 2025 Administrators Posted November 17, 2025 20 minutes ago, TheMW2Ghost said: Ok. And yeah, i'm only geetting servers within the circled region so all is good that end. I'll use the custom one tonight to see if it works in putitng me in USA once i've circled those servers Good to hear, let us know how you get on!
TheMW2Ghost Posted November 28, 2025 Author Posted November 28, 2025 Does this look right? Is this connecting me to a server outside of my geo filter?
Administrators Netduma Fraser Posted November 28, 2025 Administrators Posted November 28, 2025 It doesn't look like you've attached a photo, can you try again?
