Woke up today and Ethernet just decided it wasn’t going to work. Several restarts and re-inserts later, my only other idea is to factory restart. Short of that what can I do to fix this? System logs included.R3_2025-11-12T23:03:06.682Z_logs.txt
edit: Factory reset did NOT fix the issue.
10 hours ago, Netduma Fraser said:
Does that mean that WiFi is working? Do you have the same issue if you connect directly to your ISP modem/router?
Yes WiFi is working fine and it does seem to not connect through the ISP modem/router also but it is in bridge mode. Not sure if that affects anything.
Edit: Guess I spoke too soon. WiFi is now dropping after 30 seconds to a minute or so and will reconnect, then drop again, on a loop.
Take the ISP modem/router out of bridge mode and put the R3 WAN IP in its DMZ instead and then see if it happens again. If it does then connect directly to it and see if you have a connection (bridge wouldn't affect it in this scenario), if it doesn't then it'll be the modem or on the ISP side. If it does then it'll be the router and we can investigate further.
