Administrators Netduma Fraser Posted November 10 Administrators Posted November 10 No, start 1024 - end 65535
sw3ar Posted November 10 Author Posted November 10 I'm thinking, isn't adding reservation for specific game, a same thing? Or adding for those ports makes reservation for every game at once?
Administrators Netduma Fraser Posted November 10 Administrators Posted November 10 23 minutes ago, sw3ar said: I'm thinking, isn't adding reservation for specific game, a same thing? Or adding for those ports makes reservation for every game at once? It would reserve bandwidth for every game with that rule so you don't need to make lots of rules - also if a specific game on SmartBOOST becomes out of date you may then need to make this rule anyway to compensate sw3ar 1
Tonfaz Posted November 21 Posted November 21 Salve dove va inserita questa regola 1024 65535? Devo attivare sia udp che TCP? Smart boost deve essere comunque attivo ?
Administrators Netduma Fraser Posted November 21 Administrators Posted November 21 2 hours ago, Tonfaz said: Salve dove va inserita questa regola 1024 65535? Devo attivare sia udp che TCP? Smart boost deve essere comunque attivo ? You don't need the rule, it was for reserving bandwidth on SmartBOOST. TCP & UDP. SmartBOOST should still be enabled if you want prioritization
