Beau Posted August 1, 2025 Posted August 1, 2025 Hey everyone, I'm currently using a Geo-Filter setup on my Netduma R3 with Ping Assist enabled. It works great — during matchmaking, my ping search range often increases up to 160–200ms before placing me in a match, which is exactly what I want. However, after finishing one match and queuing again, the ping search behavior seems to reset — it starts again around 19ms and stays locked to low-latency servers, which I’m actively trying to avoid due to high congestion and competitive players. Is there any way to maintain the wide search ping range (e.g. 150–200ms) consistently between matches without rebooting the router or restarting my console every time? Any advice would be greatly appreciated! Thanks in advance.
Administrators Netduma Fraser Posted August 1, 2025 Administrators Posted August 1, 2025 That's not the purpose of the router so isn't something we'd be able to help you with specifically. You can set a range on Ping Assist though, drag the left red ball to the right to do so.
