Administrators Netduma Fraser Posted June 28, 2025 Administrators Posted June 28, 2025 2 hours ago, The Honest Tiger said: PC wired to VM as you suggested. Okay so we can rule out the router then, it'll either be the VM hub, the line or your streaming settings as your speeds are perfectly capable of dual streaming
The Honest Tiger Posted June 29, 2025 Author Posted June 29, 2025 23 hours ago, Netduma Fraser said: Okay so we can rule out the router then, it'll either be the VM hub, the line or your streaming settings as your speeds are perfectly capable of dual streaming Personally I think it might be the streamlabs servers. The way it works is rather than overloading my pc by it handling the data to two different platforms, the data is sent to the streamlabs servers which then distributes it to the platforms. By doing solo platforms, I'm streaming directly to the servers myself rather than through streamlabs via dual output.
Administrators Netduma Fraser Posted June 29, 2025 Administrators Posted June 29, 2025 10 minutes ago, The Honest Tiger said: Personally I think it might be the streamlabs servers. The way it works is rather than overloading my pc by it handling the data to two different platforms, the data is sent to the streamlabs servers which then distributes it to the platforms. By doing solo platforms, I'm streaming directly to the servers myself rather than through streamlabs via dual output. That's definitely a possibility, in that case, try streaming one using streamlabs and one using OBS and see if it works without issue
The Honest Tiger Posted June 29, 2025 Author Posted June 29, 2025 3 minutes ago, Netduma Fraser said: That's definitely a possibility, in that case, try streaming one using streamlabs and one using OBS and see if it works without issue My word I think I figured it out, basically, my youtube stream is using it's own stream key and url so my pc is trying to stream to youtube directly and via streamlabs at the same time.
Administrators Netduma Fraser Posted June 29, 2025 Administrators Posted June 29, 2025 57 minutes ago, The Honest Tiger said: My word I think I figured it out, basically, my youtube stream is using it's own stream key and url so my pc is trying to stream to youtube directly and via streamlabs at the same time. Ah so it's trying to overlap itself, that's crazy it would even allow that to happen, well done on figuring it out!
The Honest Tiger Posted June 29, 2025 Author Posted June 29, 2025 18 minutes ago, Netduma Fraser said: Ah so it's trying to overlap itself, that's crazy it would even allow that to happen, well done on figuring it out! I know, you'd think it'd be smart enough to choose one over the other and let's not celebrate yet, I need to test this theory. Netduma Fraser 1
The Honest Tiger Posted July 1, 2025 Author Posted July 1, 2025 On 6/29/2025 at 7:51 PM, The Honest Tiger said: I know, you'd think it'd be smart enough to choose one over the other and let's not celebrate yet, I need to test this theory. Just a quick update, seems I was right in the beginning, there was stability issues at streamlabs. Dual output seemed fine tonight but I'll get back to you maybe Friday to check. Netduma Fraser 1
The Honest Tiger Posted July 4, 2025 Author Posted July 4, 2025 On 7/1/2025 at 11:32 PM, The Honest Tiger said: Just a quick update, seems I was right in the beginning, there was stability issues at streamlabs. Dual output seemed fine tonight but I'll get back to you maybe Friday to check. Well an entire week without any issues so looks like it all came down to stability issues on streamlab's side. Thank you for the support though Fraser, hopefully you won't have to hear from me in the distant future.
Administrators Netduma Fraser Posted July 4, 2025 Administrators Posted July 4, 2025 9 minutes ago, The Honest Tiger said: Well an entire week without any issues so looks like it all came down to stability issues on streamlab's side. Thank you for the support though Fraser, hopefully you won't have to hear from me in the distant future. Really glad to hear you found the solution, thanks for the update, no worries at all, any questions/issues just let us know. Have a great weekend!
