The Honest Tiger Posted June 23, 2025 Author Posted June 23, 2025 On 6/22/2025 at 12:03 AM, Netduma Fraser said: Good to hear, thanks for the update! Update So I thought I found the fix when I was using the 2.5gig port on my hub even though I'm not on the package providing that port so I connected the router to a 1gig port which fixed the no internet issue. I then also read that when multi streaming using streamlabs, their servers take the single data then spread it out to the platforms meaning in my case I have to send out double the data so I put my bit rate to 16000. 3 hours of smooth streaming until it wasn't.
Administrators Netduma Fraser Posted June 23, 2025 Administrators Posted June 23, 2025 What platforms are you streaming to and in what resolution/FPS? Anything different between when you started streaming vs 3 hours later - e.g. more people in your home using the internet, hitting general peak time etc?
The Honest Tiger Posted June 23, 2025 Author Posted June 23, 2025 4 minutes ago, Netduma Fraser said: What platforms are you streaming to and in what resolution/FPS? Anything different between when you started streaming vs 3 hours later - e.g. more people in your home using the internet, hitting general peak time etc? youtube and tiktok, 1920x1080 for youtube and 1080x1920 for tiktok both at 30fps and there is literally no difference between time starting and 3 hours later.
Administrators Netduma Fraser Posted June 24, 2025 Administrators Posted June 24, 2025 Are you using H.264 or HEVC? Do you have Enforce streaming service bitrate limits enabled? You mentioned you're now using Auto for Congestion Control but what percentages are the download/upload set to? When streaming, is Traffic Prioritization actually triggerring? I still think switching to the DMZ option may help
The Honest Tiger Posted June 24, 2025 Author Posted June 24, 2025 6 hours ago, Netduma Fraser said: Are you using H.264 or HEVC? Do you have Enforce streaming service bitrate limits enabled? You mentioned you're now using Auto for Congestion Control but what percentages are the download/upload set to? When streaming, is Traffic Prioritization actually triggerring? I still think switching to the DMZ option may help I'm using my graphics card and all the settings are default apart from the bitrate and 70% congestion on both and yeah, loads of data being sent and received and finally, what exactly am I putting into DMZ?
Administrators Netduma Fraser Posted June 24, 2025 Administrators Posted June 24, 2025 40 minutes ago, The Honest Tiger said: I'm using my graphics card and all the settings are default apart from the bitrate and 70% congestion on both and yeah, loads of data being sent and received and finally, what exactly am I putting into DMZ? That's H.264 then I believe, in which case set the bitrate to 20000 then please and see how you go with that. This could be more of a fine tuning of the streaming settings rather than a router issue. Lots of data being sent and received but is it showing the red light to indicate the prioritization is active? On 6/21/2025 at 6:13 PM, Netduma Fraser said: take the VM out of modem mode, set the XR with a static/reserved IP on the VM, then set that in the DMZ
The Honest Tiger Posted June 25, 2025 Author Posted June 25, 2025 2 hours ago, Netduma Fraser said: That's H.264 then I believe, in which case set the bitrate to 20000 then please and see how you go with that. This could be more of a fine tuning of the streaming settings rather than a router issue. Lots of data being sent and received but is it showing the red light to indicate the prioritization is active? Well after 2 hours, the only message I'm getting is from youtube asking me to use the recommended 6500 kbps and now that you mention it, no, no data has been sent or recevied.
Administrators Netduma Fraser Posted June 26, 2025 Administrators Posted June 26, 2025 On 6/25/2025 at 1:46 AM, The Honest Tiger said: Well after 2 hours, the only message I'm getting is from youtube asking me to use the recommended 6500 kbps and now that you mention it, no, no data has been sent or recevied. By that do you mean streaming is working to both with no packet loss? Add the device with the Games Console service to Traffic Prioritization and also add another rule for port 443 for the device, remove any other rules you've made. If it's not being prioritized then Congestion Control also isn't being activated with it set to Auto so you can set that to Always and check again or make the rules to get it prioritizing so Congestion Control kicks in when streaming.
The Honest Tiger Posted June 26, 2025 Author Posted June 26, 2025 4 hours ago, Netduma Fraser said: By that do you mean streaming is working to both with no packet loss? Add the device with the Games Console service to Traffic Prioritization and also add another rule for port 443 for the device, remove any other rules you've made. If it's not being prioritized then Congestion Control also isn't being activated with it set to Auto so you can set that to Always and check again or make the rules to get it prioritizing so Congestion Control kicks in when streaming. Pretty much yeah but the problem just happened again now during stream with the settings you told me to do a few days ago with 20000kbps and I made a rule were every port is opened for my pc and it was active last night and even that didn't work. How can youtube not be receiving enough video for smooth streaming at 20000kbps??
Administrators Netduma Fraser Posted June 26, 2025 Administrators Posted June 26, 2025 Don't do every port because that could actually make it worse, it also bypasses Congestion Control completely. Do it with the 2 rules I mentioned and Congestion Control set to Auto Remove the rules completely and set Congestion Control to Always See if it works better one of these ways
The Honest Tiger Posted June 26, 2025 Author Posted June 26, 2025 1 hour ago, Netduma Fraser said: Don't do every port because that could actually make it worse, it also bypasses Congestion Control completely. Do it with the 2 rules I mentioned and Congestion Control set to Auto Remove the rules completely and set Congestion Control to Always See if it works better one of these ways So I'm setting my PC up with the Games Console option then adding another rule for port 1 to 443 for source and 443 for destination?
Administrators Netduma Fraser Posted June 26, 2025 Administrators Posted June 26, 2025 3 minutes ago, The Honest Tiger said: So I'm setting my PC up with the Games Console option then adding another rule for port 1 to 443 for source and 443 for destination? Yes & not port 1 just port 443 source & destination for the same PC
The Honest Tiger Posted June 26, 2025 Author Posted June 26, 2025 2 minutes ago, Netduma Fraser said: Yes & not port 1 just port 443 source & destination for the same PC What about the wireless setting? Also, am I applying this to WAN?
Administrators Netduma Fraser Posted June 26, 2025 Administrators Posted June 26, 2025 1 hour ago, The Honest Tiger said: What about the wireless setting? Also, am I applying this to WAN? Normal for ethernet, you can set apply to WAN as well, if your ISP supports it then it may provide a benefit
The Honest Tiger Posted June 27, 2025 Author Posted June 27, 2025 18 hours ago, Netduma Fraser said: Normal for ethernet, you can set apply to WAN as well, if your ISP supports it then it may provide a benefit So, an interesting development that I don't believe should have happened. With congestion set to auto and the 443 and console rules set, Traffic Prioritization was not activating but I managed a 3 hour stream with no issues. However, when I switch congestion to Always and removed those rules, I literally couldn't connect to any sort of server at all.
Administrators Netduma Fraser Posted June 27, 2025 Administrators Posted June 27, 2025 17 minutes ago, The Honest Tiger said: So, an interesting development that I don't believe should have happened. With congestion set to auto and the 443 and console rules set, Traffic Prioritization was not activating but I managed a 3 hour stream with no issues. However, when I switch congestion to Always and removed those rules, I literally couldn't connect to any sort of server at all. So no LED lighting up for the rules? Can you provide a screenshot of the rules just so I can double check please. When removed that makes more sense, you're gaming packets are getting queued behind the stream
The Honest Tiger Posted June 27, 2025 Author Posted June 27, 2025 2 minutes ago, Netduma Fraser said: So no LED lighting up for the rules? Can you provide a screenshot of the rules just so I can double check please. When removed that makes more sense, you're gaming packets are getting queued behind the stream Nothing, no packets sent or received and I know how to set up the rules... auto congestion control, PC traffic prioritization set up as a games console and rule 443 set up for both source and end point but no LED.
The Honest Tiger Posted June 27, 2025 Author Posted June 27, 2025 11 minutes ago, Netduma Fraser said: So no LED lighting up for the rules? Can you provide a screenshot of the rules just so I can double check please. When removed that makes more sense, you're gaming packets are getting queued behind the stream So I just started a stream, the LED showed for like 10 seconds then stopped for the gaming console rule but nothing for the rule 443 rule.
Administrators Netduma Fraser Posted June 27, 2025 Administrators Posted June 27, 2025 It's very bizarre it's not prioritizing with those rules. Check the IP on the PC itself then check the Device Manager on the router for the device you think it is, do the IPs match? Did you switch the VM hub to router mode and put the XR in its DMZ? Have you made any other settings changes for the PC such as putting it in the DMZ on the XR, setting Traffic Controller rules etc?
The Honest Tiger Posted June 27, 2025 Author Posted June 27, 2025 9 minutes ago, Netduma Fraser said: It's very bizarre it's not prioritizing with those rules. Check the IP on the PC itself then check the Device Manager on the router for the device you think it is, do the IPs match? Did you switch the VM hub to router mode and put the XR in its DMZ? Have you made any other settings changes for the PC such as putting it in the DMZ on the XR, setting Traffic Controller rules etc? Yeah, the hub is in router mode with the router in DMZ, apart from that, I've made no other changes other than the ones you suggested but I undid when it didn't work.
Administrators Netduma Fraser Posted June 27, 2025 Administrators Posted June 27, 2025 Do the IPs match? In WAN Settings on the XR set NAT to Open just to rule out any port issues. If it's still not working well I'd suggest you try dual streaming with the PC directly connected to the VM (you'd have to disable the DMZ) and see if you get the same issues
The Honest Tiger Posted June 27, 2025 Author Posted June 27, 2025 21 minutes ago, Netduma Fraser said: Do the IPs match? In WAN Settings on the XR set NAT to Open just to rule out any port issues. If it's still not working well I'd suggest you try dual streaming with the PC directly connected to the VM (you'd have to disable the DMZ) and see if you get the same issues Yeah my PC has a reserved IP as do all the devices and yeah I put that to open and I'll give that a try. Netduma Fraser 1
The Honest Tiger Posted June 28, 2025 Author Posted June 28, 2025 5 hours ago, Netduma Fraser said: Do the IPs match? In WAN Settings on the XR set NAT to Open just to rule out any port issues. If it's still not working well I'd suggest you try dual streaming with the PC directly connected to the VM (you'd have to disable the DMZ) and see if you get the same issues Well I can stream to tiktok but youtube just buffers like crazy now.
Administrators Netduma Fraser Posted June 28, 2025 Administrators Posted June 28, 2025 6 hours ago, The Honest Tiger said: Well I can stream to tiktok but youtube just buffers like crazy now. Is that with NAT set to Open or trying connected direct to the VM?
The Honest Tiger Posted June 28, 2025 Author Posted June 28, 2025 7 hours ago, Netduma Fraser said: Is that with NAT set to Open or trying connected direct to the VM? PC wired to VM as you suggested.
