sebastiano Posted May 19, 2025 Posted May 19, 2025 hi, i have a problem with the geofilter, basically when i configured the r3 for the first time everything worked properly, and i was only connected to bern (switzerland). after a few days the filter doesn't work anymore, it takes other servers even though the red circle is on bern. i noticed that by resetting the router everything works properly but as soon as i restart the modem it doesn't work again. i have the latest version of domos, do you recommend switching to a different version of domos to solve the problem?
Administrators Netduma Fraser Posted May 19, 2025 Administrators Posted May 19, 2025 Disable Geo-Latency and Ping Assist in the Geo-Filter menu then reboot the game and try again. If you make changes to the Geo-Filter on the game you will need to restart the game before matchmaking
sebastiano Posted May 19, 2025 Author Posted May 19, 2025 they are both disabled, I tried to restart the game several times to see if anything changed but nothing, I just reset the router and it works perfectly, red circle on berna works great, I always connect to it. restarted the router it doesn't work anymore, it goes to milan or torino. ps I noticed some white ticks on some servers after the restart that I didn't enable, as if I had given permission to play on other servers around the world.
Administrators Netduma Fraser Posted May 19, 2025 Administrators Posted May 19, 2025 What game are you playing? Can you provide a screenshot of the entire page showing what you see when you get a game outside your radius please?
sebastiano Posted May 19, 2025 Author Posted May 19, 2025 sure, the game is efootball. as you can see a white tick appeared on the amsterdam server that I have not activated.
Administrators Netduma Fraser Posted May 19, 2025 Administrators Posted May 19, 2025 For eFootball switch to custom, cover Japan, then cover the servers you want to play on, restart the game and see if it works better then.
sebastiano Posted May 20, 2025 Author Posted May 20, 2025 to cover do you mean deny access to the server? I tried it, but it doesn't work, it always connects me to Milan or Turin even if I denied access
Administrators Netduma Fraser Posted May 20, 2025 Administrators Posted May 20, 2025 13 minutes ago, sebastiano said: to cover do you mean deny access to the server? I tried it, but it doesn't work, it always connects me to Milan or Turin even if I denied access No, cover it with a polygon so it is allowed
Administrators Netduma Fraser Posted May 22, 2025 Administrators Posted May 22, 2025 20 hours ago, sebastiano said: it works, thanks for the help Great to hear that, thanks for the update!
