clarkjo Posted April 26, 2025 Posted April 26, 2025 After almost a year and a half of no fix through software updates, I finally found a workaround to the 30 second delay when connecting to ethernet on wake. it unfortunately requires buying an ethernet switch and connecting your affected devices through it, but it gets rid of the delay. i bought an 8 port netgear switch from best buy for around $25 and it hasn't affected my speeds so if you are planning on buying a switch or are just tired of waiting for a fix, a switch will solve the problem (at least in my experience)
Administrators Netduma Fraser Posted April 26, 2025 Administrators Posted April 26, 2025 That's bizarre, that would indicate that it's not the router/port then as otherwise the same issue would occur, it must be device based - what are the specific devices you're using?
clarkjo Posted April 26, 2025 Author Posted April 26, 2025 well it fixed my PC and my Sony TV, my PC is custom built with a Realtek® 2.5GbE LAN chip (copied from mb site), i dont know if thats of any help but who knows
Administrators Netduma Fraser Posted April 26, 2025 Administrators Posted April 26, 2025 28 minutes ago, clarkjo said: well it fixed my PC and my Sony TV, my PC is custom built with a Realtek® 2.5GbE LAN chip (copied from mb site), i dont know if thats of any help but who knows Could well be, on the ethernet adapter disable Energy Efficient Ethernet, restart the PC and then try again
