BiTTrigger Posted June 9 Author Posted June 9 Hello, Sorry, but this is exactly what I said a the begeining. "NoLag VPN" provide ".OVPN" files, with Encryptions Key within... In another thread, I pastes you what I've in my .OPVN file... What Can i do with this ? I believe this impossible to find a basic "Login / Password" I feel in NetDuma. But, OK, now I undertood the value of NetDuma "Global Client VPN", thx 😉 PS : I've again somes issues founding COD games... I've to open another thread for it
BiTTrigger Posted June 9 Author Posted June 9 Even if I put "Rapid Search" or if I remove "Strict Mode" Same. HELP ME !!!
Administrators Netduma Fraser Posted June 9 Administrators Posted June 9 You enter the contents of that file (open it with a notepad on your PC and copy the contents) into the configuration box on HybridVPN, then enter the login credentials, if they have none just enter 1 & 1. I've responded to your other topic.
