crazy joker Posted Friday at 06:51 PM Share Posted Friday at 06:51 PM Good evening I have a matchmaking problem on cod bo6, the search is very slow even with the geofilter disabled. My ISP is EOLO, my antenna connects to a fritz!box 7530 to which I have set the WAN ip of my netduma to "exposed host". I set the DMZ of the netduma on the ip of my xbox giving it a fixed ip. If, on the other hand, I connect the antenna cable directly to the netduma in PPPoE everything works well except for the fact that my bandwidth drops considerably from 100 to 30 and does not allow me to use it as a primary router. Where am I wrong? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted Friday at 07:21 PM Administrators Share Posted Friday at 07:21 PM Did you actually reserve an IP for the Xbox on the R1? Otherwise the IP of it can change and the DMZ will no longer be valid and may well cause issues like that. Link to comment Share on other sites More sharing options...
crazy joker Posted Friday at 08:09 PM Author Share Posted Friday at 08:09 PM I just solved the nat problem by manually opening the ports on the fritz!box instead of managing them in exposed host mode, evidently it didn't manage them well with my ISP. now they are open on both xbox and cod but the matchmaking remains slow, it tries ping 27 ping 55 ping 77 ping etc then it goes into a loop Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted Friday at 08:39 PM Administrators Share Posted Friday at 08:39 PM What ports did you forward to the R1 exactly? Link to comment Share on other sites More sharing options...
crazy joker Posted Friday at 08:55 PM Author Share Posted Friday at 08:55 PM TCP : 53, 80, 443, 1935, 3074, 3478-3480, 27014-27050 UDP: 53, 88, 500, 3074, 3478-3479, 3544, 4500, 27000-27031, 27036 I set these ports on the fritz!box to the netduma wan ip. On the netduma I set the dmz to the xbox static ip Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted Friday at 09:32 PM Administrators Share Posted Friday at 09:32 PM Just do 1-65535 TCP/UDP instead, make sure you set a reserved/static IP for the R1 on the Fritz. Make sure you've set a reserved/static IP for the Xbox on the R1. Reboot the fritz, wait 2 minutes, reboot the R1, wait 4 minutes then try again Link to comment Share on other sites More sharing options...
crazy joker Posted Friday at 10:32 PM Author Share Posted Friday at 10:32 PM Unfortunately it makes me open 255 ports at a time, so I put the old ones back! I made sure that the static addresses were set! Unfortunately it hasn't been solved yet even though I have the NAT open on both and the geofilter disabled Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted yesterday at 12:01 AM Administrators Share Posted yesterday at 12:01 AM You'll have to go back to the exposed host option then which should work fine if everything is set static. Where are you based approximately? Are you using a VPN? Are you searching in a less played playlist? Link to comment Share on other sites More sharing options...
crazy joker Posted yesterday at 01:18 AM Author Share Posted yesterday at 01:18 AM If I set exposed host the nat of cod is moderate :(! I don't use a vpn I'm in Italy in Liguria and I set the search with everything to have the greatest possible range! It behaves as if it had the geo filter active ... I also tried to reset netduma to factory settings but nothing I've been trying to solve it for 2 days! I also thought about doing a downgrade to have full bandwidth and use it as the main router! I read that before dumaos 2.0 in pppoe the netduma was able to manage a 100 connection. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted 2 hours ago Administrators Share Posted 2 hours ago Ah is that where you're checking, does it show moderate with the Geo-Filter off as well after you reboot the game? If you disable QoS fully do you get the same issue? Link to comment Share on other sites More sharing options...
