Fayad Posted February 18, 2025 Posted February 18, 2025 Wifi is slow on my phone but fast on other devices Any ideas @Admins
Administrators Netduma Fraser Posted February 18, 2025 Administrators Posted February 18, 2025 We'll need some more information than that to be able to help, can you expand on that?
LeonGulien Posted February 20, 2025 Posted February 20, 2025 The WiFi range of the Netduma is considerably less than that of your own profider's modem. I only use the WiFi of my IPS router instead of the Netduma
Fayad Posted February 21, 2025 Author Posted February 21, 2025 i have 200mbps at home On my normal router i get the full speed on my phone When i switch to netduma r3 i get only 50bps of download speed
Administrators Netduma Fraser Posted February 21, 2025 Administrators Posted February 21, 2025 8 minutes ago, Fayad said: i have 200mbps at home On my normal router i get the full speed on my phone When i switch to netduma r3 i get only 50bps of download speed What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g R3 in its DMZ, modem/bridge mode Are ALL devices connected to the R3? Have you entered those speeds into the router? How have you setup Congestion Control? How have you setup SmartBOOST? Where are you testing the speeds? What is the model of the phone? Have you split the WiFi bands and connecting to 2.4GHz or 5GHz specifically?
