Anubis2020 Posted February 16, 2025 Posted February 16, 2025 Channel width is 160mhz, confirmed using wifi analyzer but then the router reports that its running on 1200mbs mode? screenshots attached
Administrators Netduma Fraser Posted February 16, 2025 Administrators Posted February 16, 2025 Reboot the router then check again, has it changed?
Administrators Netduma Fraser Posted February 16, 2025 Administrators Posted February 16, 2025 So it's all working as expected, you're just concerned with the aesthetic of it showing a lower value when it should show the higher value?
Anubis2020 Posted February 16, 2025 Author Posted February 16, 2025 2 hours ago, Netduma Fraser said: So it's all working as expected, you're just concerned with the aesthetic of it showing a lower value when it should show the higher value? Yupe, this is not a new router, many updates for it have been released thats why i was confused and just wanted to make sure its just a bug and every thing is fine. confusing 🥴
Administrators Netduma Fraser Posted February 16, 2025 Administrators Posted February 16, 2025 If it's all working correctly you can just ignore it. It's from the NG side so I don't know what they may have changed to have it report incorrectly
