Bannon05 Posted February 9 Share Posted February 9 I upgraded to the latest version of firmware on my R3 router. This evening my WiFi has begun dropping out. Should I downgrade to the previous firmware version? Thank you… Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 9 Administrators Share Posted February 9 Factory reset first, it's a big change from the previous version, if it continues grab the log when it next happens please and we can take a look Link to comment Share on other sites More sharing options...
Bannon05 Posted February 9 Author Share Posted February 9 Thank you! A factory reset and resetting up the router corrected the issue. Recommendation to anyone upgrading to firmware v4.0.540, perform a factory reset after the upgrade. I experienced a few issues that have been resolved with the factory reset. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 9 Administrators Share Posted February 9 That's great to hear, thanks for the update! Bannon05 1 Link to comment Share on other sites More sharing options...
