Onyx Posted January 31, 2025 Posted January 31, 2025 Hi.... I would like some help getting the WireGuard config file to work in Hybrid VPN! Can someone post an example screenshot of what it should look like with all the info to get everything working when manually entering data in advanced settings? I simply can't get it to work! :-( Thanks in advance.... Im running DumaOS 3 on XR700 btw....
Administrators Netduma Fraser Posted January 31, 2025 Administrators Posted January 31, 2025 I can't recall, does HVPN have the option for Wireguard on that version/router? If so could you provide the config you're using please with the keys taken out?
