Judgey90 Posted January 7 Posted January 7 I have recently had Lightspeed broadband put my Nokia xs-2426g-a into bridge mode now I have no internet and am struggling to rig it to my nighthawk 1000 the instructions they have given are I need to start by doing this I can’t find the option on the settings page, can you help guide me through what I need to do?
Administrators Netduma Fraser Posted January 7 Administrators Posted January 7 Go to IPv6 settings page and you can set it up there
Judgey90 Posted January 7 Author Posted January 7 I did click on that but couldn’t get it to work I clicked on that then clicked on dhcp is there anything else that needs to be clicked on other then that as all that did was make this turn pink?
Administrators Netduma Fraser Posted January 7 Administrators Posted January 7 I'm pretty sure it has a DHCPIPv6 option for the IPv6 connectivity, when you've selected and applied, reboot your modem, wait 2 minutes, then reboot the XR, wait 4 minutes then check
Administrators Netduma Fraser Posted January 7 Administrators Posted January 7 If the DHCP option isn't working just use the auto detect one and see if that works after a reboot
Administrators Netduma Fraser Posted January 9 Administrators Posted January 9 Great to hear that, thanks for the update!
