mrmatthew Posted December 25, 2024 Share Posted December 25, 2024 My son's Switch won't connect to our new XR1000 router. I found this post but I don't see the Advanced Settings > Security option. I don't see Security anywhere, let alone the Access Control option to toggle. Can someone help me find this, or help me get my son's Switch connected in anyway? We got him Splatoon 3 for Christmas and it's basically unusable right now. Thank you! My Switch can connect to the router (as with a dozen other devices in the house) and my son's Switch can connect to my phone's hotspot. The router and his Switch are both up to date on software and both have been restarted several times. I cannot delete my son's Switch from the device list of the router because it says it's online, which is both incorrect and absolutely infuriating. Smart Connect has already been disabled, devices restarted after, network settings were cleared on the Switch and set back up. I tried creating a Guest network but the Switch cannot join that either. The Switch does not appear in the App list of devices at all. It does show up in the Browser UI but says it's not blocked. I have blocked and unblocked to no effect. I also cannot remove the Switch from this list because it says it's connected to the internet, which it is not. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 27, 2024 Administrators Share Posted December 27, 2024 I don't think access control is on that router and if it is then it would be disabled by default. Try this: Quote From main menu go to the gear icon select with A Scroll down to Internet Settings select with A Select the network that your trying to connect too under 'registered networks' by pressing A Select the clear settings option by pressing A Press Y to search again and setup your network connection. Link to comment Share on other sites More sharing options...
mrmatthew Posted December 27, 2024 Author Share Posted December 27, 2024 3 hours ago, Netduma Fraser said: I don't think access control is on that router and if it is then it would be disabled by default. Try this: I've tried this and it doesn't change the outcome. It can still connected to the Network Device but never clears it to connect to the internet. I think there's something to the fact that it shows up in my Router Login Device Manager but it's not blocked and when I try to delete it, it says it can't because it's online. It's obviously not online, and I've even turned the Switch off entirely. I feel like the router is stuck on this device and I don't know how to fix that. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 27, 2024 Administrators Share Posted December 27, 2024 It's not stuck or anything, it is connected to the router, just not the internet. There is an option in Advanced WiFi settings, PMF, could you toggle that and then try it again please. If it doesn't work, make sure you're connected to 2.4GHz and it's using WPA2 not WPA3 and try Link to comment Share on other sites More sharing options...
mrmatthew Posted December 27, 2024 Author Share Posted December 27, 2024 49 minutes ago, Netduma Fraser said: It's not stuck or anything, it is connected to the router, just not the internet. There is an option in Advanced WiFi settings, PMF, could you toggle that and then try it again please. If it doesn't work, make sure you're connected to 2.4GHz and it's using WPA2 not WPA3 and try The Switch is completely turned off, so I'm not sure I understand how it's connected to the router. Also, the error message says it can't be deleted because it's online, not just connected to the router. I don't see anything in the router's advanced settings called PMF, can you elaborate on what that is and where I can find it? EDIT: I found "PMF" referenced in a document alongside MU-MIMO, which I do see in the options and toggled. That didn't work either. I have ensured I'm connecting to the proper (2.4) network and using the proper (WPA2) password. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 27, 2024 Administrators Share Posted December 27, 2024 It's normal, it's not a reason or indication why it's not working. It's likely a specific issue with the switch/it needs something specific to be enabled/disabled given all other devices are working on the router so it's very unlikely the router is doing anything specifically to prevent it connecting. There are a few suggestions here https://www.nintendo.com/en-gb/Support/Nintendo-Switch/Troubleshooting/The-Nintendo-Switch-Console-Cannot-Find-Your-Wireless-Network-1322533.html?srsltid=AfmBOor8KX2bGcivX-udRu0tRdxNFz9uwJFAw9jDwsXPOs64twrh72lP Link to comment Share on other sites More sharing options...
mrmatthew Posted December 27, 2024 Author Share Posted December 27, 2024 16 minutes ago, Netduma Fraser said: It's normal, it's not a reason or indication why it's not working. It's likely a specific issue with the switch/it needs something specific to be enabled/disabled given all other devices are working on the router so it's very unlikely the router is doing anything specifically to prevent it connecting. There are a few suggestions here https://www.nintendo.com/en-gb/Support/Nintendo-Switch/Troubleshooting/The-Nintendo-Switch-Console-Cannot-Find-Your-Wireless-Network-1322533.html?srsltid=AfmBOor8KX2bGcivX-udRu0tRdxNFz9uwJFAw9jDwsXPOs64twrh72lP That article is about the Switch not seeing the network, but it does see the network. According to the Switch, it even connects to the router, it just doesn't ever connect to the internet. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 27, 2024 Administrators Share Posted December 27, 2024 On the switch, what details is it giving for the network, i.e. the IP etc? Can you provide a screenshot please? Link to comment Share on other sites More sharing options...
mrmatthew Posted December 28, 2024 Author Share Posted December 28, 2024 35 minutes ago, Netduma Fraser said: On the switch, what details is it giving for the network, i.e. the IP etc? Can you provide a screenshot please? IP and DNS settings are set to Automatic. If I click on Manual settings, they are all just strings of zeros. Proxy Settings are Off, MTU is 1400. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 28, 2024 Administrators Share Posted December 28, 2024 Use manual settings & set a static IP on the Switch with the following details IP address: 192.168.77.100 Subnet Mask: 255.255.255.0 Default gateway: 192.168.77.1 DNS: 192.168.77.1 please and see if it works. Link to comment Share on other sites More sharing options...
mrmatthew Posted December 28, 2024 Author Share Posted December 28, 2024 8 hours ago, Netduma Fraser said: Use manual settings & set a static IP on the Switch with the following details IP address: 192.168.77.100 Subnet Mask: 255.255.255.0 Default gateway: 192.168.77.1 DNS: 192.168.77.1 please and see if it works. There's a spot for a secondary DNS, so I just put in this number twice. Let me know if there's a second number. These settings made it so it couldn't even connect to the router at all. It gave the error code 2110-2003. https://en-americas-support.nintendo.com/app/answers/detail/a_id/27023/~/error-code%3A-2110-2003 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 28, 2024 Administrators Share Posted December 28, 2024 Reboot the router and grab a screenshot of how it appears on the Switch - you can remove the second DNS Link to comment Share on other sites More sharing options...
mrmatthew Posted December 28, 2024 Author Share Posted December 28, 2024 4 minutes ago, Netduma Fraser said: Reboot the router and grab a screenshot of how it appears on the Switch - you can remove the second DNS I can't remove the second DNS, it's required to save the settings as manual. I also cannot change DNS to automatic while IP settings are manual. Rebooting the router did not change the outcome here. The connection screen right now looks like this: The error message right now looks like this: As a reminder, previous before manually changing the IP/DNS settings I was able to connect to the Network Device but not the internet. That screen looked like this: Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 28, 2024 Administrators Share Posted December 28, 2024 Sorry I meant a screenshot of how you've set the manual network information. Use 8.8.8.8 instead for the secondary DNS Link to comment Share on other sites More sharing options...
mrmatthew Posted December 28, 2024 Author Share Posted December 28, 2024 22 minutes ago, Netduma Fraser said: Sorry I meant a screenshot of how you've set the manual network information. Use 8.8.8.8 instead for the secondary DNS I updated the secondary DNS to 8.8.8.8 but it still isn't working. It does connect to the Network Device again, but still won't connect to the internet. Here's my settings window: Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 28, 2024 Administrators Share Posted December 28, 2024 You've added loads of 0s, they shouldn't be there, it has to be: IP Address - 192.168.77.100 Subnet - 255.255.255.0 Gateway - 192.168.77.1 Primary DNS - 192.168.77.1 Secondary DNS - 8.8.8.8 They may give you extra spaces but you do not need to utilize them Link to comment Share on other sites More sharing options...
mrmatthew Posted December 28, 2024 Author Share Posted December 28, 2024 5 minutes ago, Netduma Fraser said: You've added loads of 0s, they shouldn't be there, it has to be: IP Address - 192.168.77.100 Subnet - 255.255.255.0 Gateway - 192.168.77.1 Primary DNS - 192.168.77.1 Secondary DNS - 8.8.8.8 They may give you extra spaces but you do not need to utilize them I didn't add those, the Switch just adds those in after you're done typing them. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 28, 2024 Administrators Share Posted December 28, 2024 That's bizarre! Just do automatic again then and grab the log from the router once you've connected it please Link to comment Share on other sites More sharing options...
mrmatthew Posted December 28, 2024 Author Share Posted December 28, 2024 34 minutes ago, Netduma Fraser said: That's bizarre! Just do automatic again then and grab the log from the router once you've connected it please How do I get a log from the router? EDIT: I found Log under Monitoring. This was the line for when I tried to connect the Switch: [DHCP IP: (192.168.1.21)] to MAC address 74:84:69:56:D5:E9, Saturday, Dec 28,2024 15:35:09 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 29, 2024 Administrators Share Posted December 29, 2024 Can you provide the entire log from the bottom of the System Information page after please? That entry is fine, no issues there Link to comment Share on other sites More sharing options...
mrmatthew Posted December 29, 2024 Author Share Posted December 29, 2024 24 minutes ago, Netduma Fraser said: Can you provide the entire log from the bottom of the System Information page after please? That entry is fine, no issues there I just tried connecting twice, this time it didn't even connect to the Network Device which it usually does. Here's the log: Dec 29 00:24:06 XR1000 local1.notice CEVENT_APP[27368]: 1735431846826 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735431846826] 243 Dec 29 00:24:06 XR1000 local1.notice CEVENT_APP[27368]: 1735431846827 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 00:24:06 XR1000 local1.notice CEVENT_APP[27368]: 1735431846828 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735431846828] 243 Dec 28 16:24:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 00:24:18 XR1000 local1.notice CEVENT_APP[27368]: 1735431858397 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735431858397] 243 Dec 29 00:24:18 XR1000 local1.notice CEVENT_APP[27368]: 1735431858398 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 00:24:18 XR1000 local1.notice CEVENT_APP[27368]: 1735431858399 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 00:24:18 XR1000 local1.notice CEVENT_APP[27368]: 1735431858399 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735431858399] 243 Dec 29 00:24:42 XR1000 local1.notice CEVENT_APP[27368]: 1735431882260 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735431882260] 243 Dec 29 00:24:42 XR1000 local1.notice CEVENT_APP[27368]: 1735431882261 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 00:24:42 XR1000 local1.notice CEVENT_APP[27368]: 1735431882264 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 00:24:42 XR1000 local1.notice CEVENT_APP[27368]: 1735431882263 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735431882263] 243 Dec 29 00:25:34 XR1000 local1.notice CEVENT_APP[27368]: 1735431934993 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735431934993] 243 Dec 29 00:25:34 XR1000 local1.notice CEVENT_APP[27368]: 1735431934994 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 00:25:34 XR1000 local1.notice CEVENT_APP[27368]: 1735431934996 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 29, 2024 Administrators Share Posted December 29, 2024 This is the entire log file? Link to comment Share on other sites More sharing options...
mrmatthew Posted December 29, 2024 Author Share Posted December 29, 2024 7 hours ago, Netduma Fraser said: This is the entire log file? Dec 29 01:56:56 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 01:58:56 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:00:56 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:02:56 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:04:56 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:06:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:07:31 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 02:07:31 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 02:08:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:10:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:12:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:14:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:16:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:18:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:20:57 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:22:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:24:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:26:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 10:28:11 XR1000 local1.notice CEVENT_APP[27368]: 1735468091041 wl0 74:84:69:56:D5:E9 0 0000 0004 0000 Driver -- E_DEAUTH/5 163 Dec 29 10:28:11 XR1000 local1.notice CEVENT_APP[27368]: 1735468091043 wl0 74:84:69:56:D5:E9 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 10:28:11 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 10:28:11 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 02:28:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:30:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:32:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:34:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 10:35:48 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:4e:1d:aa IEEE 802.11: disassociated 103 Dec 29 10:35:48 XR1000 local1.notice CEVENT_APP[27368]: 1735468548677 wl0 7C:2E:BD:4E:1D:AA 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 10:35:48 XR1000 local1.notice CEVENT_APP[27368]: 1735468548677 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735468548677] 244 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569683 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735468569683] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569684 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569684 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735468569684] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569690 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569690 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735468569690] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569690 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735468569690] 243 Dec 29 10:36:09 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:4e:1d:aa IEEE 802.11: associated 100 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569692 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569706 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735468569706] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569708 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735468569708] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569712 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735468569712] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569713 wl0 7C:2E:BD:4E:1D:AA 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735468569713] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569715 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735468569715] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569717 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735468569717] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569718 wl0 7C:2E:BD:4E:1D:AA 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735468569718] 243 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569719 wl0 7C:2E:BD:4E:1D:AA 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735468569719] 243 Dec 29 10:36:09 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:4e:1d:aa RADIUS: starting accounting session 4B47AC56DE091A29 129 Dec 29 10:36:09 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:4e:1d:aa WPA: pairwise key handshake completed (RSN) 120 Dec 29 10:36:09 XR1000 local1.notice CEVENT_APP[27368]: 1735468569725 wl0 7C:2E:BD:4E:1D:AA 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 02:36:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 02:36:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 02:36:58 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:37:09 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 02:37:09 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 02:38:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:40:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:42:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:44:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:46:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 10:47:26 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:e4:88:54 IEEE 802.11: disassociated 103 Dec 29 10:47:26 XR1000 local1.notice CEVENT_APP[27368]: 1735469246723 wl0 7C:2E:BD:E4:88:54 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 10:47:26 XR1000 local1.notice CEVENT_APP[27368]: 1735469246722 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735469246722] 244 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267711 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735469267711] 243 Dec 29 10:47:47 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:e4:88:54 IEEE 802.11: associated 100 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267723 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267723 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735469267723] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267723 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735469267723] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267728 wl0 7C:2E:BD:E4:88:54 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267729 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267729 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735469267729] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267729 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735469267729] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267730 wl0 7C:2E:BD:E4:88:54 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267730 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267730 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735469267730] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267730 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735469267730] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267731 wl0 7C:2E:BD:E4:88:54 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267731 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267732 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735469267732] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267735 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267738 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735469267738] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267739 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735469267739] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267740 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267740 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735469267740] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267743 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735469267743] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267746 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735469267746] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267747 wl0 7C:2E:BD:E4:88:54 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735469267747] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267747 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735469267747] 243 Dec 29 10:47:47 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:e4:88:54 RADIUS: starting accounting session 22BF81C347471A7A 129 Dec 29 10:47:47 XR1000 daemon.info hostapd: wl0: STA 7c:2e:bd:e4:88:54 WPA: pairwise key handshake completed (RSN) 120 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267751 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735469267751] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267753 wl0 7C:2E:BD:E4:88:54 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735469267753] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267753 wl0 7C:2E:BD:E4:88:54 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735469267753] 243 Dec 29 10:47:47 XR1000 local1.notice CEVENT_APP[27368]: 1735469267754 wl0 7C:2E:BD:E4:88:54 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 02:47:49 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 02:47:49 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 02:48:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:50:59 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:53:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:55:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:57:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 02:59:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:01:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:03:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:05:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:07:00 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 11:08:52 XR1000 local1.notice CEVENT_APP[27368]: 1735470532176 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735470532176] 243 Dec 29 11:08:52 XR1000 local1.notice CEVENT_APP[27368]: 1735470532177 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 11:08:52 XR1000 local1.notice CEVENT_APP[27368]: 1735470532179 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735470532179] 243 Dec 29 03:09:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:09:02 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 03:09:02 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 03:11:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:13:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:15:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:17:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:19:00 XR1000 cron.info crond[8742]: USER nobody pid 5700 cmd /etc/bdupd_start_schedule.sh 105 Dec 29 03:19:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:21:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:23:01 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:25:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:27:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:29:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:31:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:33:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:35:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:37:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 03:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 03:39:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:41:02 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:43:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:45:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:47:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:49:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:51:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 11:52:35 XR1000 daemon.info hostapd: wl0: STA b0:2a:43:22:84:ad IEEE 802.11: disassociated 103 Dec 29 11:52:35 XR1000 local1.notice CEVENT_APP[27368]: 1735473155568 wl0 B0:2A:43:22:84:AD 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 11:52:35 XR1000 local1.notice CEVENT_APP[27368]: 1735473155568 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735473155568] 244 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176535 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735473176535] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176540 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176536 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735473176536] 243 Dec 29 11:52:56 XR1000 daemon.info hostapd: wl0: STA b0:2a:43:22:84:ad IEEE 802.11: associated 100 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176543 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176544 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735473176544] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176544 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735473176544] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176545 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176560 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735473176560] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176562 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735473176562] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176578 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735473176578] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176579 wl0 B0:2A:43:22:84:AD 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735473176579] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176581 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735473176581] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176583 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735473176583] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176584 wl0 B0:2A:43:22:84:AD 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735473176584] 243 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176585 wl0 B0:2A:43:22:84:AD 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735473176585] 243 Dec 29 11:52:56 XR1000 daemon.info hostapd: wl0: STA b0:2a:43:22:84:ad RADIUS: starting accounting session 7807086DA2402E64 129 Dec 29 11:52:56 XR1000 daemon.info hostapd: wl0: STA b0:2a:43:22:84:ad WPA: pairwise key handshake completed (RSN) 120 Dec 29 11:52:56 XR1000 local1.notice CEVENT_APP[27368]: 1735473176586 wl0 B0:2A:43:22:84:AD 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 03:52:57 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 03:52:57 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 03:53:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:55:03 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:57:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 03:59:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:01:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:03:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:05:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:07:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:09:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 12:09:16 XR1000 local1.notice CEVENT_APP[27368]: 1735474156042 wl0 74:84:69:56:D5:E9 0 0000 0004 0000 Driver -- E_DEAUTH/5 163 Dec 29 12:09:16 XR1000 local1.notice CEVENT_APP[27368]: 1735474156042 wl0 74:84:69:56:D5:E9 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 12:09:16 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 12:09:16 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 04:11:04 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:13:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:15:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:17:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:19:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:20:54 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 04:20:54 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 04:21:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:23:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:25:05 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 12:27:00 XR1000 local1.notice CEVENT_APP[27368]: 1735475220552 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735475220552] 243 Dec 29 12:27:00 XR1000 local1.notice CEVENT_APP[27368]: 1735475220553 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 12:27:00 XR1000 local1.notice CEVENT_APP[27368]: 1735475220553 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735475220553] 243 Dec 29 04:27:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 12:27:11 XR1000 local1.notice CEVENT_APP[27368]: 1735475231207 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735475231207] 243 Dec 29 12:27:11 XR1000 local1.notice CEVENT_APP[27368]: 1735475231208 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 12:27:11 XR1000 local1.notice CEVENT_APP[27368]: 1735475231208 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 12:27:11 XR1000 local1.notice CEVENT_APP[27368]: 1735475231208 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735475231208] 243 Dec 29 04:28:26 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 04:28:26 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 04:29:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:31:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:33:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:35:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:37:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:37:08 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 04:37:08 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 04:39:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:41:06 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:43:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 12:44:54 XR1000 local1.notice CEVENT_APP[27368]: 1735476294992 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735476294992] 243 Dec 29 12:44:54 XR1000 local1.notice CEVENT_APP[27368]: 1735476294993 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 12:44:54 XR1000 local1.notice CEVENT_APP[27368]: 1735476294993 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735476294993] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295002 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295003 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735476295003] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295005 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735476295005] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295006 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 12:44:55 XR1000 daemon.info hostapd: wl0: STA c4:9d:ed:56:fc:95 IEEE 802.11: associated 100 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295036 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735476295036] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295037 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735476295037] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295039 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735476295039] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295040 wl0 C4:9D:ED:56:FC:95 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 161 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735476295040] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295142 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735476295142] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295146 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735476295146] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295149 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735476295149] 243 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295150 wl0 C4:9D:ED:56:FC:95 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735476295150] 243 Dec 29 12:44:55 XR1000 daemon.info hostapd: wl0: STA c4:9d:ed:56:fc:95 RADIUS: starting accounting session 1764894ADEC4E56C 129 Dec 29 12:44:55 XR1000 daemon.info hostapd: wl0: STA c4:9d:ed:56:fc:95 WPA: pairwise key handshake completed (RSN) 120 Dec 29 12:44:55 XR1000 local1.notice CEVENT_APP[27368]: 1735476295155 wl0 C4:9D:ED:56:FC:95 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 04:44:55 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 04:44:55 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 04:45:00 XR1000 user.warn com.netdumasoftware.devicemanager: config write 'com.netdumasoftware.devicemanager.database' 131 Dec 29 04:45:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:47:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:49:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:51:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:53:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:55:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:57:07 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 04:59:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:01:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297379 wl0 C4:9D:ED:56:FC:95 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735477297379] 246 Dec 29 13:01:37 XR1000 daemon.info hostapd: wl0: STA c4:9d:ed:56:fc:95 IEEE 802.11: disassociated 103 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297384 wl0 C4:9D:ED:56:FC:95 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 13:01:37 XR1000 daemon.info hostapd: wl0: STA c4:9d:ed:56:fc:95 IEEE 802.11: disassociated 103 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297392 wl0 C4:9D:ED:56:FC:95 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297393 wl0 C4:9D:ED:56:FC:95 24 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735477297393] 244 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297393 wl0 C4:9D:ED:56:FC:95 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297394 wl0 C4:9D:ED:56:FC:95 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297395 wl0 C4:9D:ED:56:FC:95 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297395 wl0 C4:9D:ED:56:FC:95 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297396 wl0 C4:9D:ED:56:FC:95 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:01:37 XR1000 local1.notice CEVENT_APP[27368]: 1735477297397 wl0 C4:9D:ED:56:FC:95 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 05:01:37 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 05:01:37 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 05:03:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:05:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:05:46 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 05:05:46 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 05:07:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:09:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:10:59 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 05:10:59 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 05:11:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:13:08 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:15:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:17:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:19:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 13:20:14 XR1000 local1.notice CEVENT_APP[27368]: 1735478414106 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735478414106] 243 Dec 29 13:20:14 XR1000 local1.notice CEVENT_APP[27368]: 1735478414107 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:20:14 XR1000 local1.notice CEVENT_APP[27368]: 1735478414108 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 13:20:14 XR1000 local1.notice CEVENT_APP[27368]: 1735478414107 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735478414107] 243 Dec 29 05:21:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:23:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:25:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:27:09 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:29:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:31:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:33:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:35:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 05:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 05:37:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:39:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:41:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:43:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:45:10 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 13:47:07 XR1000 local1.notice CEVENT_APP[27368]: 1735480027104 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735480027104] 243 Dec 29 13:47:07 XR1000 local1.notice CEVENT_APP[27368]: 1735480027105 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 13:47:07 XR1000 local1.notice CEVENT_APP[27368]: 1735480027105 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 13:47:07 XR1000 local1.notice CEVENT_APP[27368]: 1735480027105 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735480027105] 243 Dec 29 05:47:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:47:36 XR1000 user.warn com.netdumasoftware.desktop: Cloud sync: Router timezone is not UTC '-800' 113 Dec 29 05:47:36 XR1000 user.info com.netdumasoftware.desktop: Cloudsync Themes result 'false','All mirrors are down' 122 Dec 29 05:48:38 XR1000 user.info com.netdumasoftware.pingheatmap: Ping Heatmap looking for updates... 107 Dec 29 05:48:39 XR1000 user.info com.netdumasoftware.pingheatmap: Downloading files at mirror: http://api.netduma.com/file/cloud_updates/ping_heatmap/0000000278/NETDUMA_V1/gpg/cloud-0000000278-ping_heatmap-NETDUMA_V1-gpg.cloud 232 Dec 29 05:48:39 XR1000 user.warn com.netdumasoftware.pingheatmap: Cloud sync: Router timezone is not UTC '-800' 117 Dec 29 05:48:39 XR1000 user.info com.netdumasoftware.pingheatmap: Cloudsync Ping Heatmap result 'true','Cloud is up to date' 130 Dec 29 05:49:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:50:19 XR1000 user.info com.netdumasoftware.adblocker: Adblocker looking for updates... 102 Dec 29 05:50:19 XR1000 user.info com.netdumasoftware.adblocker: Downloading files at mirror: http://api.netduma.com/file/cloud_updates/adblocker/0000000008/NETDUMA_V1/gpg/cloud-0000000008-adblocker-NETDUMA_V1-gpg.cloud 224 Dec 29 05:50:26 XR1000 user.info com.netdumasoftware.adblocker: Cloudsync Adblocker result 'true','nil' 109 Dec 29 05:51:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:53:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:54:05 XR1000 user.info lua: Geofilter looking for updates... 76 Dec 29 05:54:06 XR1000 user.info lua: Downloading files at mirror: http://api.netduma.com/file/cloud_updates/geofilter/0000000294/NETDUMA_V1/gpg/cloud-0000000294-geofilter-NETDUMA_V1-gpg.cloud 198 Dec 29 05:54:06 XR1000 user.warn lua: Cloud sync: Router timezone is not UTC '-800' 89 Dec 29 05:54:06 XR1000 user.info lua: Cloudsync Geofilter result 'true','Cloud is up to date' 99 Dec 29 05:55:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:57:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 05:58:25 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 05:58:25 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 05:59:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:01:11 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:03:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:03:36 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 06:03:36 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 06:05:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:07:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:09:02 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 06:09:02 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 06:09:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:11:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:13:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:15:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:17:12 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:19:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:21:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:23:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:25:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:27:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:28:19 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 06:28:19 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 06:29:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:31:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:33:13 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:33:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 06:33:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 06:35:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 06:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 06:37:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:38:17 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 06:38:17 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 06:39:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:41:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:43:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:45:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:47:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 14:47:35 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 14:47:35 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 14:47:35 XR1000 local1.notice CEVENT_APP[27368]: 1735483655078 wl0 74:84:69:56:D5:E9 0 0000 0004 0000 Driver -- E_DEAUTH/5 163 Dec 29 14:47:35 XR1000 local1.notice CEVENT_APP[27368]: 1735483655079 wl0 74:84:69:56:D5:E9 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 06:49:14 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 14:50:02 XR1000 local1.notice CEVENT_APP[27368]: 1735483802535 wl1 86:D3:E0:64:35:71 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 14:50:02 XR1000 local1.notice CEVENT_APP[27368]: 1735483802534 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735483802534] 244 Dec 29 14:50:02 XR1000 daemon.info hostapd: wl1: STA 86:d3:e0:64:35:71 IEEE 802.11: disassociated 103 Dec 29 06:51:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:53:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:55:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:57:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 06:59:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:01:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:03:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:05:15 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:07:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 15:09:06 XR1000 local1.notice CEVENT_APP[27368]: 1735484946088 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735484946088] 243 Dec 29 15:09:06 XR1000 local1.notice CEVENT_APP[27368]: 1735484946089 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 15:09:06 XR1000 local1.notice CEVENT_APP[27368]: 1735484946090 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735484946090] 243 Dec 29 07:09:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:11:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:13:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:15:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:17:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:19:10 XR1000 user.info com.netdumasoftware.devicemanager: DPI looking for updates... 100 Dec 29 07:19:11 XR1000 user.info com.netdumasoftware.devicemanager: Sent request to https://api.netduma.com/api/v1/cloud/url/DPI with headers {"content-length":"163","content-type":"application/json","Connection":"keep-alive","Authorization":"Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJyMl91c2VyIiwiZXhwIjoxNzM2NDQ0ODc0fQ.cXZ5eI7W8tjRChPgZCLEoFQnCR3oM1rUYpSkO2E4Op0"} 385 Dec 29 07:19:11 XR1000 user.info com.netdumasoftware.devicemanager: Error: Received error message 404 with body {"detail":"This version of DumaOS cannot download this app."} 179 Dec 29 07:19:11 XR1000 user.info com.netdumasoftware.devicemanager: Error: the server replied with an invalid message. 124 Dec 29 07:19:16 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:21:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:21:28 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 07:21:28 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 07:23:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:25:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:27:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:29:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:31:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:33:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:35:17 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:37:09 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 07:37:09 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 07:37:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:39:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:41:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981665 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735486981665] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981666 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981665 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735486981665] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981677 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981675 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735486981675] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981675 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735486981675] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981677 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 15:43:01 XR1000 daemon.info hostapd: wl1: STA 86:d3:e0:64:35:71 IEEE 802.11: associated 100 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981694 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735486981694] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981694 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735486981694] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981721 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735486981721] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981722 wl1 86:D3:E0:64:35:71 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 173 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735486981722] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981723 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735486981723] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981723 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735486981723] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981735 wl1 86:D3:E0:64:35:71 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735486981735] 243 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981736 wl1 86:D3:E0:64:35:71 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 151 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735486981736] 243 Dec 29 15:43:01 XR1000 daemon.info hostapd: wl1: STA 86:d3:e0:64:35:71 RADIUS: starting accounting session 15E2EB5111074E25 129 Dec 29 15:43:01 XR1000 daemon.info hostapd: wl1: STA 86:d3:e0:64:35:71 WPA: pairwise key handshake completed (RSN) 120 Dec 29 15:43:01 XR1000 local1.notice CEVENT_APP[27368]: 1735486981737 wl1 86:D3:E0:64:35:71 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 07:43:01 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 07:43:01 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 07:43:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:45:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:47:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:49:18 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:51:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:53:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:55:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:57:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:59:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 07:59:37 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 07:59:37 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 08:01:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:03:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 16:04:55 XR1000 local1.notice CEVENT_APP[27368]: 1735488295998 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735488295998] 243 Dec 29 16:04:56 XR1000 local1.notice CEVENT_APP[27368]: 1735488296000 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 16:04:56 XR1000 local1.notice CEVENT_APP[27368]: 1735488296000 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:04:56 XR1000 local1.notice CEVENT_APP[27368]: 1735488296000 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735488296000] 243 Dec 29 08:05:19 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:07:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:09:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:11:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:13:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:15:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:17:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:19:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:21:20 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:23:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:25:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:27:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:29:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:31:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990988 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735489990988] 243 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990992 wl0 74:84:69:56:D5:E9 0 0000 0001 0000 Driver -- E_DEAUTH/5 163 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990992 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990992 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735489990992] 243 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990995 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990995 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735489990995] 243 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990997 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735489990997] 243 Dec 29 16:33:10 XR1000 local1.notice CEVENT_APP[27368]: 1735489990999 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 16:33:11 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: associated 100 Dec 29 16:33:11 XR1000 local1.notice CEVENT_APP[27368]: 1735489991146 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735489991146] 243 Dec 29 16:33:11 XR1000 local1.notice CEVENT_APP[27368]: 1735489991148 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735489991148] 243 Dec 29 16:33:12 XR1000 local1.notice CEVENT_APP[27368]: 1735489992149 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735489992149] 243 Dec 29 16:33:12 XR1000 local1.notice CEVENT_APP[27368]: 1735489992150 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735489992150] 243 Dec 29 16:33:12 XR1000 local1.notice CEVENT_APP[27368]: 1735489992167 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735489992167] 243 Dec 29 16:33:12 XR1000 local1.notice CEVENT_APP[27368]: 1735489992168 wl0 74:84:69:56:D5:E9 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735489992168] 243 Dec 29 16:33:12 XR1000 local1.notice CEVENT_APP[27368]: 1735489992168 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735489992168] 243 Dec 29 16:33:12 XR1000 local1.notice CEVENT_APP[27368]: 1735489992171 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735489992171] 243 Dec 29 16:33:13 XR1000 local1.notice CEVENT_APP[27368]: 1735489993171 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735489993171] 243 Dec 29 16:33:13 XR1000 local1.notice CEVENT_APP[27368]: 1735489993173 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735489993173] 243 Dec 29 16:33:13 XR1000 local1.notice CEVENT_APP[27368]: 1735489993174 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735489993174] 243 Dec 29 16:33:13 XR1000 local1.notice CEVENT_APP[27368]: 1735489993175 wl0 74:84:69:56:D5:E9 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735489993175] 243 Dec 29 16:33:13 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 RADIUS: starting accounting session 3B8CB7F899F98F5C 129 Dec 29 16:33:13 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 WPA: pairwise key handshake completed (RSN) 120 Dec 29 16:33:13 XR1000 local1.notice CEVENT_APP[27368]: 1735489993176 wl0 74:84:69:56:D5:E9 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 08:33:17 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:33:17 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 16:33:20 XR1000 local1.notice CEVENT_APP[27368]: 1735490000157 wl0 74:84:69:56:D5:E9 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735490000157] 246 Dec 29 16:33:20 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 16:33:20 XR1000 daemon.info hostapd: wl0: STA 74:84:69:56:d5:e9 IEEE 802.11: disassociated 103 Dec 29 16:33:20 XR1000 local1.notice CEVENT_APP[27368]: 1735490000161 wl0 74:84:69:56:D5:E9 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 16:33:20 XR1000 local1.notice CEVENT_APP[27368]: 1735490000162 wl0 74:84:69:56:D5:E9 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 08:33:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:35:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:35:22 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:35:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 08:35:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:35:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 08:35:24 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:35:24 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135778 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735490135778] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135785 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:35:35 XR1000 daemon.info hostapd: wl1: STA bc:d7:d4:58:2d:0a IEEE 802.11: associated 100 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135790 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735490135790] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135791 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135791 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735490135791] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135792 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735490135792] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135792 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135800 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490135800] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135800 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490135800] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135802 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490135802] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135802 wl1 BC:D7:D4:58:2D:0A 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 173 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490135802] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135804 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490135804] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135804 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490135804] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135806 wl1 BC:D7:D4:58:2D:0A 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490135806] 243 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135807 wl1 BC:D7:D4:58:2D:0A 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 151 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490135807] 243 Dec 29 16:35:35 XR1000 daemon.info hostapd: wl1: STA bc:d7:d4:58:2d:0a RADIUS: starting accounting session E8D7114C9CEC9BB5 129 Dec 29 16:35:35 XR1000 daemon.info hostapd: wl1: STA bc:d7:d4:58:2d:0a WPA: pairwise key handshake completed (RSN) 120 Dec 29 16:35:35 XR1000 local1.notice CEVENT_APP[27368]: 1735490135808 wl1 BC:D7:D4:58:2D:0A 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 08:35:36 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:35:36 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 08:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:37:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 08:37:21 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:39:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:41:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:43:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 16:43:37 XR1000 local1.notice CEVENT_APP[27368]: 1735490617127 wl0 B4:17:A8:DB:3F:D5 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 16:43:37 XR1000 local1.notice CEVENT_APP[27368]: 1735490617127 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735490617127] 244 Dec 29 16:43:37 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 IEEE 802.11: disassociated 103 Dec 29 08:45:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739644 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735490739644] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739644 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739644 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735490739644] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739654 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739654 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735490739654] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739655 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735490739655] 243 Dec 29 16:45:39 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 IEEE 802.11: associated 100 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739666 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739670 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490739670] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739670 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490739670] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739695 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490739695] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739696 wl0 B4:17:A8:DB:3F:D5 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490739696] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739698 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490739698] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739700 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490739700] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739705 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490739705] 243 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739706 wl0 B4:17:A8:DB:3F:D5 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490739706] 243 Dec 29 16:45:39 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 RADIUS: starting accounting session 241ABCC0B6BED720 129 Dec 29 16:45:39 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 WPA: pairwise key handshake completed (RSN) 120 Dec 29 16:45:39 XR1000 local1.notice CEVENT_APP[27368]: 1735490739712 wl0 B4:17:A8:DB:3F:D5 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 08:45:40 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:45:40 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 16:46:28 XR1000 daemon.info hostapd: wl0: STA 02:21:4a:75:ad:18 IEEE 802.11: disassociated 103 Dec 29 16:46:28 XR1000 local1.notice CEVENT_APP[27368]: 1735490788229 wl0 02:21:4A:75:AD:18 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 16:46:28 XR1000 local1.notice CEVENT_APP[27368]: 1735490788229 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735490788229] 244 Dec 29 16:46:28 XR1000 local1.notice CEVENT_APP[27368]: 1735490788230 wl0 02:21:4A:75:AD:18 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805489 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735490805489] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805490 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805490 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735490805490] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805501 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805501 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735490805501] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805501 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735490805501] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805502 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 16:46:45 XR1000 daemon.info hostapd: wl0: STA 02:21:4a:75:ad:18 IEEE 802.11: associated 100 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805515 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490805515] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805518 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490805518] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805564 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490805564] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805565 wl0 02:21:4A:75:AD:18 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490805565] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805567 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490805567] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805569 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490805569] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805576 wl0 02:21:4A:75:AD:18 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490805576] 243 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805576 wl0 02:21:4A:75:AD:18 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490805576] 243 Dec 29 16:46:45 XR1000 daemon.info hostapd: wl0: STA 02:21:4a:75:ad:18 RADIUS: starting accounting session 27E780C23556F31D 129 Dec 29 16:46:45 XR1000 daemon.info hostapd: wl0: STA 02:21:4a:75:ad:18 WPA: pairwise key handshake completed (RSN) 120 Dec 29 16:46:45 XR1000 local1.notice CEVENT_APP[27368]: 1735490805579 wl0 02:21:4A:75:AD:18 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 08:46:45 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:46:45 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 16:46:49 XR1000 local1.notice CEVENT_APP[27368]: 1735490809107 wl0 B4:17:A8:DB:3F:D5 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 16:46:49 XR1000 local1.notice CEVENT_APP[27368]: 1735490809108 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735490809108] 244 Dec 29 16:46:49 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 IEEE 802.11: disassociated 103 Dec 29 16:47:06 XR1000 local1.notice CEVENT_APP[27368]: 1735490826354 wl0 4E:D5:87:DE:8F:DE 0 0000 0004 0000 Driver -- E_DEAUTH/5 163 Dec 29 16:47:06 XR1000 daemon.info hostapd: wl0: STA 4e:d5:87:de:8f:de IEEE 802.11: disassociated 103 Dec 29 16:47:06 XR1000 local1.notice CEVENT_APP[27368]: 1735490826356 wl0 4E:D5:87:DE:8F:DE 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828640 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735490828640] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828646 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828641 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735490828641] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828649 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828649 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735490828649] 243 Dec 29 16:47:08 XR1000 daemon.info hostapd: wl0: STA 4e:d5:87:de:8f:de IEEE 802.11: associated 100 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828650 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735490828650] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828650 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver -- E_REASSOC_IND/10 163 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828665 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490828665] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828666 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490828666] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828668 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490828668] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828671 wl0 4E:D5:87:DE:8F:DE 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490828671] 243 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828672 wl0 4E:D5:87:DE:8F:DE 0 0000 0003 0000 Driver -- E_DEAUTH_IND/6 163 Dec 29 16:47:08 XR1000 local1.notice CEVENT_APP[27368]: 1735490828672 wl0 4E:D5:87:DE:8F:DE 0 0000 0000 0000 Driver RX DEAUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 10/0x000A/DEAUTH_RX 0x40000000 1735490828672] 244 Dec 29 16:47:08 XR1000 daemon.info hostapd: wl0: STA 4e:d5:87:de:8f:de IEEE 802.11: disassociated 103 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829728 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735490829728] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829733 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829732 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735490829732] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829738 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829738 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735490829738] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829738 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735490829738] 243 Dec 29 16:47:09 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 IEEE 802.11: associated 100 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829741 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829754 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490829754] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829756 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490829756] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829782 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490829782] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829783 wl0 B4:17:A8:DB:3F:D5 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490829783] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829784 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490829784] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829785 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490829785] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829794 wl0 B4:17:A8:DB:3F:D5 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490829794] 243 Dec 29 16:47:09 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 RADIUS: starting accounting session 33F2FB1C759376F6 129 Dec 29 16:47:09 XR1000 daemon.info hostapd: wl0: STA b4:17:a8:db:3f:d5 WPA: pairwise key handshake completed (RSN) 120 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829795 wl0 B4:17:A8:DB:3F:D5 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490829795] 243 Dec 29 16:47:09 XR1000 local1.notice CEVENT_APP[27368]: 1735490829797 wl0 B4:17:A8:DB:3F:D5 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 08:47:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:47:10 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831671 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735490831671] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831672 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831672 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735490831672] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831687 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831688 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735490831688] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831688 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735490831688] 243 Dec 29 16:47:11 XR1000 daemon.info hostapd: wl0: STA 18:e7:b0:62:39:24 IEEE 802.11: associated 100 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831689 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831705 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490831705] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831706 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490831706] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831707 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490831707] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831707 wl0 18:E7:B0:62:39:24 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490831707] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831709 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735490831709] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831712 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735490831712] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831714 wl0 18:E7:B0:62:39:24 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735490831714] 243 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831715 wl0 18:E7:B0:62:39:24 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735490831715] 243 Dec 29 16:47:11 XR1000 daemon.info hostapd: wl0: STA 18:e7:b0:62:39:24 RADIUS: starting accounting session CA1F826B7CCF5F9E 129 Dec 29 16:47:11 XR1000 daemon.info hostapd: wl0: STA 18:e7:b0:62:39:24 WPA: pairwise key handshake completed (RSN) 120 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831716 wl0 18:E7:B0:62:39:24 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 16:47:11 XR1000 local1.notice CEVENT_APP[27368]: 1735490831801 wl0 4E:D5:87:DE:8F:DE 0 0000 0007 0000 Driver -- E_DEAUTH/5 163 Dec 29 08:47:11 XR1000 user.debug com.netdumasoftware.devicemanager: Marking device that is marked 192.168.1.29 46 39. 124 Dec 29 08:47:13 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 08:47:13 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 08:47:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:49:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:51:22 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:53:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:55:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:57:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 08:59:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 09:01:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:02:30 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:02:30 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:02:30 XR1000 local1.notice CEVENT_APP[27368]: 1735491750393 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735491750393] 246 Dec 29 17:02:30 XR1000 local1.notice CEVENT_APP[27368]: 1735491750396 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:02:30 XR1000 local1.notice CEVENT_APP[27368]: 1735491750396 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763172 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735491763172] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763173 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763173 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735491763173] 243 Dec 29 17:02:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763183 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763183 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735491763183] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763183 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735491763183] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763190 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763198 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491763198] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763200 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491763200] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763205 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491763205] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763206 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491763206] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763206 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491763206] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763209 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491763209] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763211 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491763211] 243 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763211 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491763211] 243 Dec 29 17:02:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session 11364D46AF02CDBE 129 Dec 29 17:02:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763214 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763267 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735491763267] 246 Dec 29 17:02:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763271 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:02:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491763272 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:02:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772826 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735491772826] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772828 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772829 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735491772829] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772836 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:02:52 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772843 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735491772843] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772844 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735491772844] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772844 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772854 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491772854] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772857 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491772857] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772858 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491772858] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772859 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491772859] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772861 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491772861] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772864 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491772864] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772864 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491772864] 243 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772865 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491772865] 243 Dec 29 17:02:52 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session D6D0F165098E6C9E 129 Dec 29 17:02:52 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:02:52 XR1000 local1.notice CEVENT_APP[27368]: 1735491772867 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:02:53 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:02:53 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:03:03 XR1000 local1.notice CEVENT_APP[27368]: 1735491783977 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735491783977] 246 Dec 29 17:03:03 XR1000 local1.notice CEVENT_APP[27368]: 1735491783978 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:03 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:03 XR1000 local1.notice CEVENT_APP[27368]: 1735491783980 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:03 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787725 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735491787725] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787726 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787726 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735491787726] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787735 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:03:07 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787736 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735491787736] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787736 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735491787736] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787743 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787750 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491787750] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787751 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491787751] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787752 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491787752] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787753 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491787753] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787753 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491787753] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787757 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491787757] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787758 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491787758] 243 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787759 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491787759] 243 Dec 29 17:03:07 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session C610DACB08DBDAC0 129 Dec 29 17:03:07 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:03:07 XR1000 local1.notice CEVENT_APP[27368]: 1735491787760 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:03:07 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:03:07 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:03:17 XR1000 local1.notice CEVENT_APP[27368]: 1735491797851 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735491797851] 246 Dec 29 17:03:17 XR1000 local1.notice CEVENT_APP[27368]: 1735491797852 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:17 XR1000 local1.notice CEVENT_APP[27368]: 1735491797856 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:17 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:17 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 09:03:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814444 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735491814444] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814445 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814445 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735491814445] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814455 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814455 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735491814455] 243 Dec 29 17:03:34 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814455 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735491814455] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814456 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814470 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491814470] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814472 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491814472] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814473 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491814473] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814474 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491814474] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814474 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491814474] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814477 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491814477] 243 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814478 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491814478] 243 Dec 29 17:03:34 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session E89C0A524C0560CB 129 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814479 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491814479] 243 Dec 29 17:03:34 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:03:34 XR1000 local1.notice CEVENT_APP[27368]: 1735491814480 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:03:34 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:03:34 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:03:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491823271 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735491823271] 246 Dec 29 17:03:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:43 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491823277 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:43 XR1000 local1.notice CEVENT_APP[27368]: 1735491823278 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829148 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735491829148] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829151 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829151 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735491829151] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829159 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829159 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735491829159] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829159 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735491829159] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829160 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:03:49 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829174 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491829174] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829177 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491829177] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829180 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491829180] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829181 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491829181] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829182 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491829182] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829185 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491829185] 243 Dec 29 17:03:49 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session C969123C9E861D1C 129 Dec 29 17:03:49 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829188 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491829188] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829189 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491829189] 243 Dec 29 17:03:49 XR1000 local1.notice CEVENT_APP[27368]: 1735491829189 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:03:49 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:03:49 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:03:58 XR1000 local1.notice CEVENT_APP[27368]: 1735491838303 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735491838303] 246 Dec 29 17:03:58 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:58 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:03:58 XR1000 local1.notice CEVENT_APP[27368]: 1735491838310 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:03:58 XR1000 local1.notice CEVENT_APP[27368]: 1735491838310 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877781 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735491877781] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877782 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877783 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735491877783] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877791 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877792 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735491877792] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877792 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735491877792] 243 Dec 29 17:04:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877803 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877808 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491877808] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877809 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491877809] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877813 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491877813] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877814 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491877814] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877814 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735491877814] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877819 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735491877819] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877820 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735491877820] 243 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877820 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735491877820] 243 Dec 29 17:04:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session F49CD69B5250D90D 129 Dec 29 17:04:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:04:37 XR1000 local1.notice CEVENT_APP[27368]: 1735491877821 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:04:37 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:04:37 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 09:05:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 09:07:23 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:07:30 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:07:30 XR1000 local1.notice CEVENT_APP[27368]: 1735492050163 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492050163] 246 Dec 29 17:07:30 XR1000 local1.notice CEVENT_APP[27368]: 1735492050166 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:07:30 XR1000 local1.notice CEVENT_APP[27368]: 1735492050167 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:07:30 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085512 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492085512] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085513 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085517 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492085517] 243 Dec 29 17:08:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085527 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085526 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492085526] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085526 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492085526] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085527 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085544 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492085544] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085546 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492085546] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085547 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492085547] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085548 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492085548] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085548 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492085548] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085557 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492085557] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085559 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492085559] 243 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085560 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492085560] 243 Dec 29 17:08:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session BCBB0E41C7848ED5 129 Dec 29 17:08:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:08:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492085561 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:08:05 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:08:05 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:08:18 XR1000 local1.notice CEVENT_APP[27368]: 1735492098513 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492098513] 246 Dec 29 17:08:18 XR1000 local1.notice CEVENT_APP[27368]: 1735492098516 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:08:18 XR1000 local1.notice CEVENT_APP[27368]: 1735492098518 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:08:18 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:08:18 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100846 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492100846] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100848 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100848 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492100848] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100860 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100860 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492100860] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100860 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492100860] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100861 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:08:20 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100876 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492100876] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100877 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492100877] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100880 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492100880] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100881 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492100881] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100881 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492100881] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100884 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492100884] 243 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100885 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492100885] 243 Dec 29 17:08:20 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session 0475B883F1B03D11 129 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100886 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492100886] 243 Dec 29 17:08:20 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:08:20 XR1000 local1.notice CEVENT_APP[27368]: 1735492100887 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:08:21 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:08:21 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:08:31 XR1000 local1.notice CEVENT_APP[27368]: 1735492111227 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492111227] 246 Dec 29 17:08:31 XR1000 local1.notice CEVENT_APP[27368]: 1735492111229 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:08:31 XR1000 local1.notice CEVENT_APP[27368]: 1735492111231 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:08:31 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:08:31 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 09:09:02 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:09:02 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 09:09:24 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209534 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492209534] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209534 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209534 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492209534] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209546 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209546 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492209546] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209548 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492209548] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209550 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:10:09 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209569 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492209569] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209571 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492209571] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209573 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492209573] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209574 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492209574] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209576 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492209576] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209578 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492209578] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209579 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492209579] 243 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209580 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492209580] 243 Dec 29 17:10:09 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session 31E4AE7B8E43065D 129 Dec 29 17:10:09 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:10:09 XR1000 local1.notice CEVENT_APP[27368]: 1735492209582 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:10:09 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:10:09 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:10:18 XR1000 local1.notice CEVENT_APP[27368]: 1735492218455 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492218455] 246 Dec 29 17:10:18 XR1000 local1.notice CEVENT_APP[27368]: 1735492218458 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:10:18 XR1000 local1.notice CEVENT_APP[27368]: 1735492218460 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:10:18 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:10:18 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223337 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492223337] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223343 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223338 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492223338] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223348 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223348 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492223348] 243 Dec 29 17:10:23 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223349 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492223349] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223353 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223367 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492223367] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223368 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492223368] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223371 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492223371] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223372 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492223372] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223373 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492223373] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223374 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492223374] 243 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223376 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492223376] 243 Dec 29 17:10:23 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session 2FC60B26B0E4691E 129 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223377 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492223377] 243 Dec 29 17:10:23 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:10:23 XR1000 local1.notice CEVENT_APP[27368]: 1735492223379 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:10:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:10:23 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:10:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492237595 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492237595] 246 Dec 29 17:10:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492237597 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:10:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492237599 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:10:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:10:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 09:11:24 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297760 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492297760] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297761 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297761 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492297761] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297773 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297773 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492297773] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297773 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492297773] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297774 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:11:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297791 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492297791] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297795 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492297795] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297796 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492297796] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297797 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492297797] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297797 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492297797] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297801 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492297801] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297802 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492297802] 243 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297803 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492297803] 243 Dec 29 17:11:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session 3E070816A7687513 129 Dec 29 17:11:37 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:11:37 XR1000 local1.notice CEVENT_APP[27368]: 1735492297805 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:11:38 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:11:38 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 09:13:24 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 09:15:24 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:16:03 XR1000 local1.notice CEVENT_APP[27368]: 1735492563238 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492563238] 246 Dec 29 17:16:03 XR1000 local1.notice CEVENT_APP[27368]: 1735492563241 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:16:03 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:16:03 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:16:03 XR1000 local1.notice CEVENT_APP[27368]: 1735492563245 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566549 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492566549] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566551 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566551 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492566551] 243 Dec 29 17:16:06 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566567 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566565 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492566565] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566565 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492566565] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566567 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566575 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492566575] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566577 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492566577] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566578 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492566578] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566579 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492566579] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566581 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492566581] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566583 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492566583] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566584 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492566584] 243 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566585 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492566585] 243 Dec 29 17:16:06 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session B9A987D28AE7D604 129 Dec 29 17:16:06 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:16:06 XR1000 local1.notice CEVENT_APP[27368]: 1735492566587 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:16:06 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:16:06 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:16:17 XR1000 local1.notice CEVENT_APP[27368]: 1735492577167 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492577167] 246 Dec 29 17:16:17 XR1000 local1.notice CEVENT_APP[27368]: 1735492577169 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:16:17 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:16:17 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:16:17 XR1000 local1.notice CEVENT_APP[27368]: 1735492577173 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601213 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492601213] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601213 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601213 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492601213] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601225 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:16:41 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601226 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492601226] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601226 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492601226] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601227 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601243 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492601243] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601245 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492601245] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601247 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492601247] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601248 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492601248] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601249 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492601249] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601252 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492601252] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601252 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492601252] 243 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601253 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492601253] 243 Dec 29 17:16:41 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session 4745E90E4D053731 129 Dec 29 17:16:41 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:16:41 XR1000 local1.notice CEVENT_APP[27368]: 1735492601254 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:16:41 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:16:41 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 17:16:49 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:16:49 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:16:49 XR1000 local1.notice CEVENT_APP[27368]: 1735492609978 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492609978] 246 Dec 29 17:16:49 XR1000 local1.notice CEVENT_APP[27368]: 1735492609982 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:16:49 XR1000 local1.notice CEVENT_APP[27368]: 1735492609983 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 09:17:24 XR1000 user.warn com.netdumasoftware.procmanager: Rapp com.netdumasoftware.ngdilsync has not responded to watchdog 136 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680865 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492680865] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680866 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680866 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492680866] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680871 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680870 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492680870] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680870 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492680870] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680871 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver -- E_REASSOC_IND/10 163 Dec 29 17:18:00 XR1000 daemon.info hostapd: wl1: STA cc:47:40:04:74:5d IEEE 802.11: associated 100 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680889 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492680889] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680890 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492680890] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680892 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492680892] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680893 wl1 CC:47:40:04:74:5D 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 173 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492680893] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680893 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492680893] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680893 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492680893] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680895 wl1 CC:47:40:04:74:5D 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492680895] 243 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680895 wl1 CC:47:40:04:74:5D 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 151 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492680895] 243 Dec 29 17:18:00 XR1000 daemon.info hostapd: wl1: STA cc:47:40:04:74:5d RADIUS: starting accounting session 711AD05458B30403 129 Dec 29 17:18:00 XR1000 daemon.info hostapd: wl1: STA cc:47:40:04:74:5d WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:18:00 XR1000 local1.notice CEVENT_APP[27368]: 1735492680897 wl1 CC:47:40:04:74:5D 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 09:18:00 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Dec 29 09:18:00 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89 Dec 29 09:18:01 XR1000 user.debug com.netdumasoftware.devicemanager: Marking device that is marked 192.168.1.19 19 27. 124 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745073 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX AUTH_RX [CE: 1 24 1/0x0001/CE_D2C 24 6/0x0006/AUTH_RX 0x40000000 1735492745073] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745073 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_AUTH_IND/4 163 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745074 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX AUTH_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 0/0x0000/AUTH_TX 0x80000000 1735492745074] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745086 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC/7 163 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745085 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX ASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 7/0x0007/ASSOC_RX 0x40000000 1735492745085] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745085 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX ASSOC_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 1/0x0001/ASSOC_TX 0x80000000 1735492745085] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745087 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver -- E_ASSOC_IND/8 163 Dec 29 17:19:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: associated 100 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745161 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492745161] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745162 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492745162] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745168 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492745168] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745169 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M2_RX [CE: 1 159 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492745169] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745171 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_QUEUED [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000000 1735492745171] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745193 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver TX EAP_TX_SUCCESS [CE: 1 24 1/0x0001/CE_D2C 24 2/0x0002/EAP_TX 0x80000001 1735492745193] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745197 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX EAP_RX [CE: 1 24 1/0x0001/CE_D2C 24 8/0x0008/EAP_RX 0x40000000 1735492745197] 243 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745198 wl0 1A:E3:48:79:97:7F 6144 0000 0000 0000 EAPD RX M4_RX [CE: 1 137 4/0x0004/CE_D2A 24 2/0x0002/-- 0x40000001 1735492745198] 243 Dec 29 17:19:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f RADIUS: starting accounting session E0B53CEEDFA6A675 129 Dec 29 17:19:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f WPA: pairwise key handshake completed (RSN) 120 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745205 wl0 1A:E3:48:79:97:7F 0 0136 0000 0000 Driver -- E_AUTHORIZED/136 163 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745241 wl0 1A:E3:48:79:97:7F 0 0000 0000 0000 Driver RX DISASSOC_RX [CE: 1 24 1/0x0001/CE_D2C 24 9/0x0009/DISASSOC_RX 0x40000000 1735492745241] 246 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745244 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:19:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Dec 29 17:19:05 XR1000 local1.notice CEVENT_APP[27368]: 1735492745250 wl0 1A:E3:48:79:97:7F 0 0000 0008 0000 Driver -- E_DISASSOC_IND/12 163 Dec 29 17:19:05 XR1000 daemon.info hostapd: wl0: STA 1a:e3:48:79:97:7f IEEE 802.11: disassociated 103 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 29, 2024 Administrators Share Posted December 29, 2024 Thank you, do you get similar entries when other devices are connected to the router? Link to comment Share on other sites More sharing options...
mrmatthew Posted December 30, 2024 Author Share Posted December 30, 2024 4 hours ago, Netduma Fraser said: Thank you, do you get similar entries when other devices are connected to the router? I don't know, I'm not even sure what any of this means. Link to comment Share on other sites More sharing options...
