Badgerslayer7 Posted December 1, 2024 Posted December 1, 2024 Hello. Just purchased this router in the black friday deal. Unfortunately I cannot get this to work the same way as my asus router did. With my asus I was able to connect directly to my supplied ont. Using 123@skydsl|123 with client identifier 61. Can any help me to get this to work in the same way. Many thanks
Administrators Netduma Fraser Posted December 1, 2024 Administrators Posted December 1, 2024 Connect it to your existing router for the moment, complete the wizard and then upgrade to the latest firmware, either from here: https://forum.netduma.com/topic/57039-new-r3-firmware-dumaos-40290/ or the interface, then attempt to use those details again to connect.
Badgerslayer7 Posted December 1, 2024 Author Posted December 1, 2024 I've updated to the latest firmware. Still doesn't work.
Administrators Netduma Fraser Posted December 1, 2024 Administrators Posted December 1, 2024 Where are you entering the details exactly? Can you provide a screenshot please?
Badgerslayer7 Posted December 1, 2024 Author Posted December 1, 2024 In the dhpc settings of wan page. I've packed it away for now and gone back to my asus one.
Administrators Netduma Fraser Posted December 1, 2024 Administrators Posted December 1, 2024 Try abc123@skydsl|abc123 when you get a chance and see if that works instead Badgerslayer7 1
Badgerslayer7 Posted December 2, 2024 Author Posted December 2, 2024 Still not working. Left it for 20 mins still not connecting. Does it automatically select option 61.
Badgerslayer7 Posted December 2, 2024 Author Posted December 2, 2024 It's ok I've managed to get it working.
Administrators Netduma Fraser Posted December 2, 2024 Administrators Posted December 2, 2024 Glad to hear you got it sorted, likely just a reboot would be needed after entering, thanks for the update!
