Tonfaz Posted November 29, 2024 Posted November 29, 2024 Si può Limitare la banda con Smart boost disattivo in qualche modo ?grazie a tutti
Administrators Netduma Fraser Posted November 29, 2024 Administrators Posted November 29, 2024 The only way potentially would be to set your speeds to lower than you have but I'm not sure if it will work and if it doesn't then no you can't limit the bandwidth with SmartBOOST disabled.
