L7NALMARI Posted October 30, 2024 Posted October 30, 2024 What the best sitting for bo6 traffic prioritization ports ? UpNp? MTU ? port forwarding? dns server ? any advice ? Share ur sitting dinego 1
Infoseye Posted October 30, 2024 Posted October 30, 2024 Everyone's settings is unique, alot of factors you would have to put into consideration such as your location, ISP, bandwidth etc. netdumar isn't a plug and play device unfortunately you would have to get your hands dirty, research and do your finds what works for you. I would advice you start reading and apply the settings on the knowledge base page first, use the settings as a base line. Understand what each feature or settings does and how it affects your in game experience then tweak the settings. Doing this over time you will discover what works and what doesn't work for you, hope this helps you get started.
Administrators Netduma Fraser Posted October 31, 2024 Administrators Posted October 31, 2024 As above, everyone's connections are different, there isn't a one size fits all series of settings. We can provide the general suggestions that should work for most people but they are just a suggestion, tweaking from there is always advised. I will say adjusting MTU & DNS will not make a difference. UPnP/Port Forwarding as long as you have an open NAT you don't need to adjust them. I'd focus on the Geo-Filter, Congestion Control and SmartBOOST. Also keep in mind it's launch time, the game connection will be at it's worst right now with the amount of players, it happens every year.
Tony Posted November 3, 2024 Posted November 3, 2024 Hello @Netduma Fraser ✌️ No solution for the moment ?? Because Black Ops6 is totally unplayable on PC for me right now 😅 I died behind the walls and the hit detection is horrible 😅 Thank you 🙏
VeeDot Posted November 3, 2024 Posted November 3, 2024 1 hour ago, Tony said: Hello @Netduma Fraser ✌️ No solution for the moment ?? Because Black Ops6 is totally unplayable on PC for me right now 😅 I died behind the walls and the hit detection is horrible 😅 Thank you 🙏 tbf its more to do with the game atm - alot of bug fixes needed plus player base is high so servers are trash. will need to wait for it to calm down possibly
Administrators Netduma Fraser Posted November 3, 2024 Administrators Posted November 3, 2024 5 hours ago, Tony said: Hello @Netduma Fraser ✌️ No solution for the moment ?? Because Black Ops6 is totally unplayable on PC for me right now 😅 I died behind the walls and the hit detection is horrible 😅 Thank you 🙏 We rarely need to put out a specific 'fix' for a game in terms of improving the connection, you have all the tools at your disposal to get the best connection possible. Other than that, it's as above, it's always like this every year at launch, the servers get slammed and so the connection is at it's worse, it will start to cool down and then Christmas will hit and then it'll happen again.
