Hello, I need help fixing the netduma, download and upload speeds are stuck even after a factory reset
It's likely the ethernet cables you're using - check the WAN and LAN page, it will tell you which ones are limited to 100Mbps.
No, no problems with the internet cables, it's since I wanted to adjust the connection speed to get an A+
Enable Speed Test Bypass, what do you get then? Are devices directly connected to the router? Are you testing over WiFi?
Here is the order of my configuration:
1) my Internet service provider with netduma in DMZ
2) the netduma connected to my internet provider
3) all my devices connected to netduma
As for the tests, I do them from the Xbox Series X with a wired connection.
I even tested the dumas os app on my phone and got the same results
