FeaRvPain Posted October 29, 2024 Author Share Posted October 29, 2024 No worries Many thanks and all the best John Link to comment Share on other sites More sharing options...
FeaRvPain Posted October 30, 2024 Author Share Posted October 30, 2024 All good to go this end Cheers John Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted October 31, 2024 Administrators Share Posted October 31, 2024 They forced an upgrade through, you may have noticed the router go down while that happened, hopefully when it's back online you'll be on the latest update Link to comment Share on other sites More sharing options...
FeaRvPain Posted October 31, 2024 Author Share Posted October 31, 2024 Many thanks but unfortunatly it is still on ver 3.2.280. All the best John Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted October 31, 2024 Administrators Share Posted October 31, 2024 Okay he'll try again Link to comment Share on other sites More sharing options...
FeaRvPain Posted October 31, 2024 Author Share Posted October 31, 2024 Cheers But I have disconected it for now I will reconnect it tomorrow. All the best John Netduma Fraser 1 Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 1, 2024 Author Share Posted November 1, 2024 All connected back up 🤞 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 1, 2024 Administrators Share Posted November 1, 2024 We tried again but could you reboot quickly and get it back up for us? FeaRvPain 1 Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 1, 2024 Author Share Posted November 1, 2024 Rebooting now Cheers John Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 1, 2024 Administrators Share Posted November 1, 2024 Did it upgrade at all? Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 1, 2024 Author Share Posted November 1, 2024 Sorry for not replying sooner I was playing COD WZ and sorry to say it has not upgraded and was stuck it a boot loop again. All the best John Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 1, 2024 Administrators Share Posted November 1, 2024 Okay no worries, there is another way to try when we force it, I'll let the team know to try it on Monday, thanks for your patience Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 2, 2024 Author Share Posted November 2, 2024 Cheers Fraser, I hope you have a great weekend Cheers John Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 2, 2024 Administrators Share Posted November 2, 2024 Thank you, and you! Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 4, 2024 Author Share Posted November 4, 2024 All connected back up Cheers John Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 4, 2024 Administrators Share Posted November 4, 2024 Okay we tried again, please let us know if that worked Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 4, 2024 Author Share Posted November 4, 2024 Many thanks but sorry to say but no change still on ver 3.3.280 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 4, 2024 Administrators Share Posted November 4, 2024 Okay thanks, I'm checking in with the team FeaRvPain 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 4, 2024 Administrators Share Posted November 4, 2024 Your router will have reset, hopefully now it's upgraded Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 4, 2024 Author Share Posted November 4, 2024 Cheers It worked this time I am setting it up now Many thanks and all the best John Link to comment Share on other sites More sharing options...
FeaRvPain Posted November 4, 2024 Author Share Posted November 4, 2024 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 4, 2024 Administrators Share Posted November 4, 2024 That's brilliant to hear, thanks for the update! FeaRvPain 1 Link to comment Share on other sites More sharing options...
chris1990 Posted November 8, 2024 Share Posted November 8, 2024 Hi Fraser i also have this same issue tried to update Firmware to latest version 3.3.280, same as the screenshot the last guy put up, won't update and stuck in boot loop, now I can't access the router login page atall no matter what I try. I've done hard reset and all of the suggestions above please help there seems to be nothing I can do to fix it, also the WiFi will not show up no matter how many times i reset the router, the update seems to have caused major issues and now my connection drops every time I try to play a game. Pretty sure it's exactly the same issue the guy who made this post had Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 8, 2024 Administrators Share Posted November 8, 2024 13 hours ago, chris1990 said: Hi Fraser i also have this same issue tried to update Firmware to latest version 3.3.280, same as the screenshot the last guy put up, won't update and stuck in boot loop, now I can't access the router login page atall no matter what I try. I've done hard reset and all of the suggestions above please help there seems to be nothing I can do to fix it, also the WiFi will not show up no matter how many times i reset the router, the update seems to have caused major issues and now my connection drops every time I try to play a game. Pretty sure it's exactly the same issue the guy who made this post had I see you've made a new topic, I'll respond to you there Link to comment Share on other sites More sharing options...
