SamyX Posted October 13, 2024 Posted October 13, 2024 (edited) I own Netduma R2 and I play FC25 from Turkey. According to the ping map, it appears to be at least 35ms on the Milan server. but when I select that point I cannot connect to any game. Do I need to open a port? Can you help me? Edited October 13, 2024 by SamyX
Administrators Netduma Fraser Posted October 13, 2024 Administrators Posted October 13, 2024 Italian and Spanish servers seem to be the hardest to force - do you have the same issue if you try connecting to other servers with the radius?
SamyX Posted October 13, 2024 Author Posted October 13, 2024 When I add Warsaw and Frankfurt in polygon mode, there is no problem. But while the Milan server gives the best ping, my goal is to connect there.
Administrators Netduma Fraser Posted October 13, 2024 Administrators Posted October 13, 2024 Okay so the router is filtering correctly then which means it won't be a problem on your side, it will just be that the Milan server is not always available to connect to. Have it in your radius but don't force it exclusively.
Administrators Netduma Fraser Posted October 14, 2024 Administrators Posted October 14, 2024 What do you mean exactly? Port forwarding works but it wouldn't help with this
SamyX Posted October 19, 2024 Author Posted October 19, 2024 I tried geography filtering again but it wasn't working. why is it not active? My connection to Warsaw and Frankfurt seems perfect, but it connects to a server other than them. connects it to the Bern.
Administrators Netduma Fraser Posted October 19, 2024 Administrators Posted October 19, 2024 Can you provide a screenshot of the Geo-Filter page showing what you see when you get a game outside your radius please? Preferably using a PC to do so.
SamyX Posted October 23, 2024 Author Posted October 23, 2024 On 10/19/2024 at 8:44 PM, Netduma Fraser said: Can you provide a screenshot of the Geo-Filter page showing what you see when you get a game outside your radius please? Preferably using a PC to do so. Can you help me for the full installation? What exactly settings should I make? Obviously there is something I did wrong.
Administrators Netduma Fraser Posted October 24, 2024 Administrators Posted October 24, 2024 If you can provide the screenshot I can better advise on why that specifically may be happening. There are guides available at support.netduma.com and there are also some videos over on YT that can help as well e.g. https://www.youtube.com/playlist?list=PLCU0-ELvZkOoPSep37e5VmdNatkIWYNxU
