R3 loses ppoe connection every 24 hrs
extremeborg
 Share
  • Replies 50
Top Posters In This Topic
23 hours ago, extremeborg said:
Again disconneted with thos firmware, i rebooted and i will see what happens
Did you factory reset after the install? If not please try that and let us know - we've had some promising feedback on it so far
32 minutes ago, extremeborg said:
Tried 4.0291
40290
4.0285 every loses connection after 24 hrs , but exact hour and minute
If you're having the issue only .291 will potentially fix it for you - could you provide the log when you get the disconnect on that firmware please? Does the connection regain itself or do you need to reboot? Sounds like it might be DHCP if it's that scheduled
8 hours ago, kaptakiller said:
Good morning I have the same disconnecting issue situation could please give access to the .291 firmware to see if it helps me out, thank you
Added https://forum.netduma.com/topic/56332-r3-disconnections/?do=findComment&comment=424833
  • 4 weeks later...
On 10/12/2024 at 7:06 PM, Netduma Fraser said:
Hello everyone,
I'm experiencing exactly the same issue. I even had my ISP intervene twice to check the optical cabinet, and I had my ONT replaced this morning, but the problem persists. The issue is as follows: there’s a loss of LAN signal between the ONT and the Netduma R3. When I log into the R3 after disconnection, both the PPPoE Internet Status and Internet Port show as "Offline." A simple reboot of the R3 reconnects it. This problem occur randomly, sometimes twice or more a day sometimes one or two times during the week... Not every 24h as extremeborg problem
For reference, there’s no switch in my setup; the ONT is connected directly to the R3's WAN port.
@kaptakiller and @extremeborg, did the .291 firmware resolve your issues? I’d love to test it if it could help fix my problem.
Thanks in advance!
1 hour ago, BernieNoel66 said:
Hello everyone,
Thanks in advance!
We are looking into that issue for the PPPoE disconnect but I've given you access to try it to try it and see if it is more stable for you
  • 2 weeks later...
Hi,
My R3 keeps disconnecting from WAN. At first it was happening occasionally but now it's very frequent. It also disconnected my user and password, it was set to "remember me".
I had reset it and configured the PPPoE again, now it's happening very often. It goes back online if I let it be for a while but mostly I manually reboot it and then it goes back up.
What's the solution here?
Thanks
7 hours ago, Julian83 said:
Hi,
Thanks
I've given you Early Access, please try the firmware there and see if it works better please https://forum.netduma.com/forum/151-netduma-r3-early-access/
  • 1 month later...
 Share
