Administrators Netduma Fraser Posted October 3, 2024 Administrators Posted October 3, 2024 What do you mean by a WiFi switch exactly? Do you mean an extender? If so yes.
Finkler Posted October 3, 2024 Author Posted October 3, 2024 No as I have Ethernet from my router plugged into a switch which then gives me 5 more Ethernet ports as my Ethernet cable runs though my roof into my setup.
Administrators Netduma Fraser Posted October 3, 2024 Administrators Posted October 3, 2024 Yes it will work with a wired switch, it would be better to have all devices connected behind the R3 for QoS to be more effective though
Finkler Posted October 3, 2024 Author Posted October 3, 2024 Ok thabks but like settings like geo fence will work right? Cause that’s the one thing I was worried about. I can also just have the net duma in my room and buy Ethernet cables but I wasn’t sure if that would work since does it have to be the Netduma provided cable that I have to plug into the wan port for it to work?
Administrators Netduma Fraser Posted October 3, 2024 Administrators Posted October 3, 2024 Yes that feature will still work - other ethernet cables can be used
