SimMAUDeon Posted September 30, 2024 Posted September 30, 2024 My LAN is set up as 172.17.2.0/24 I used to be able to connect to the web GUI of my Humax modem at 192.168.100.1 without having to change any IP address settings on my computer. Now, suddenly, I can't...It tries and then times out. Any ideas re what I might have inadvertently done when I rebuilt the network after upgrading the XR1000 firmware? TIA
Administrators Netduma Fraser Posted October 1, 2024 Administrators Posted October 1, 2024 Behind the XR are you able to ping the modem LAN IP in command prompt? Nothing really would have changed to affect that between the updates honestly and that would be a NG change and they rarely touch that area.
SimMAUDeon Posted October 4, 2024 Author Posted October 4, 2024 On 10/1/2024 at 10:16 AM, Netduma Fraser said: Behind the XR are you able to ping the modem LAN IP in command prompt? Nothing really would have changed to affect that between the updates honestly and that would be a NG change and they rarely touch that area. No...also I don't remember if I ever pinged it via CMD before. Had no reason to because it worked from day 1 with the modem. THX for the quick response.. 👍
Administrators Netduma Fraser Posted October 4, 2024 Administrators Posted October 4, 2024 It's most likely the humax blocking it somehow, what operation mode is the humax in?
