fae7787 Posted September 28, 2024 Posted September 28, 2024 Ciao ragazzi , il mio smart Boost non rileva quando sto giocando a efootball. Cosa posso fare?
Administrators Netduma Fraser Posted September 28, 2024 Administrators Posted September 28, 2024 What firmware are you on and what platform are you playing on? What are your SmartBOOST rules? fae7787 1
fae7787 Posted September 28, 2024 Author Posted September 28, 2024 1 hour ago, Netduma Fraser said: What firmware are you on and what platform are you playing on? What are your SmartBOOST rules? firmware : 4-0-290 Device :ps5
fae7787 Posted September 28, 2024 Author Posted September 28, 2024 Another problem when i play on efotball is the mini lag on Milan Server ...... But is the best server near my positizion . IN the other server i don t have any lag.
Administrators Netduma Fraser Posted September 28, 2024 Administrators Posted September 28, 2024 Is it appearing in the middle part when gaming even if it's showing offline on the right? If you use the more basic way without the numbers does it work? If you add it as a device instead does it work? There isn't any reason from the router perspective why you would have lag on one server only
fae7787 Posted September 28, 2024 Author Posted September 28, 2024 33 minutes ago, Netduma Fraser said: Is it appearing in the middle part when gaming even if it's showing offline on the right?Se si utilizza il metodo più elementare senza i numeri, funziona? Se invece lo si aggiunge come dispositivo, funziona? There isn't any reason from the router perspective why you would have lag on one server only Is it appearing in the middle part when gaming even if it's showing offline on the right? No , i have try with to the game " the finals " and in this case show me only the category Gaming Like a device , i see the correctly device ( Ps5 ) . Doesn' t work with the elemntary mode.
Administrators Netduma Fraser Posted September 28, 2024 Administrators Posted September 28, 2024 Use the device mode for now, it will still prioritize the game, a better cloud update is coming in the meantime
fae7787 Posted September 29, 2024 Author Posted September 29, 2024 3 hours ago, Netduma Fraser said: Use the device mode for now, it will still prioritize the game, a better cloud update is coming in the meantime How can active it ?
Administrators Netduma Fraser Posted September 29, 2024 Administrators Posted September 29, 2024 7 hours ago, fae7787 said: How can active it ? Click Devices on SmartBOOST and select your console
fae7787 Posted October 6, 2024 Author Posted October 6, 2024 On 9/29/2024 at 11:24 AM, Netduma Fraser said: Click Devices on SmartBOOST and select your console Ho notato una cosa strana : su alcuni server , tipo il server di torino di Efootbal mi apre la porta 1214 ( o qualcosa di simile ) e lo smartBoost si attiva correttamente per Efootbal, altre porte invece no.
Administrators Netduma Fraser Posted October 6, 2024 Administrators Posted October 6, 2024 What other ports are being opened when it doesn't show?
fae7787 Posted October 6, 2024 Author Posted October 6, 2024 1 hour ago, Netduma Fraser said: What other ports are being opened when it doesn't show? di solito quelle maggiori di 30000 , ma sto ancora facendo dei test....
fae7787 Posted October 6, 2024 Author Posted October 6, 2024 In questo caso mi ha aperto la 1402 e lo smart boost funziona correttamente
fae7787 Posted October 6, 2024 Author Posted October 6, 2024 Other port than product a correctly smarboost : 1422 21194 21490
Administrators Netduma Fraser Posted October 6, 2024 Administrators Posted October 6, 2024 Thank you, I will pass that on for the team to look at
fae7787 Posted October 29, 2024 Author Posted October 29, 2024 in merito a questa discussione ; ho creato questa semplice regola di blocco sulla playstation , adesso lo smart boost per efootball si attiva correttamente. Secondo me questa non attivazione è dovuta a un bug.
Administrators Netduma Fraser Posted October 30, 2024 Administrators Posted October 30, 2024 So blocking ports the game doesn't use makes SmartBOOST detect it correctly?
fae7787 Posted October 30, 2024 Author Posted October 30, 2024 8 hours ago, Netduma Fraser said: So blocking ports the game doesn't use makes SmartBOOST detect it correctly? Sembra davvero strano , considera che ho fatto pure un reset del R3 perchè non capivo , ma risuccede pure a macchina resettata. c' entra qualcosa il PPOE ? Non so veramente piu che pensare
fae7787 Posted October 30, 2024 Author Posted October 30, 2024 8 hours ago, Netduma Fraser said: So blocking ports the game doesn't use makes SmartBOOST detect it correctly? Nel precedente post avevo sbagliato allegato , la regola è questa : , Scusa per l errore di prima
fae7787 Posted October 30, 2024 Author Posted October 30, 2024 13 hours ago, Netduma Fraser said: So blocking ports the game doesn't use makes SmartBOOST detect it correctly? anyway , ho resettato alle impostazioni di fabbrica r3 : Sono connesso in PPOE al modem Ho dato un ip alla playstation. Non ho fatto regole di port forwarding. Non ho bloccato porte. Lo smart Boost non si attiva sui seguenti giochi : Efootball Helldivers 2 La playstationo la vedo solo nella modalità dispositivi. Cosa devo fare per risolvere ?
fae7787 Posted October 30, 2024 Author Posted October 30, 2024 H 19 hours ago, Netduma Fraser said: So blocking ports the game doesn't use makes SmartBOOST detect it correctly? Ho fatto un ulteriore reset , lo smart boost si attiva ( a volte ) solo quando viente rispettato un filtro , oppure è evidenziato da un area che selezioniamo. Non si potrebbe migliorare la situazione facendolo attivare sempre ?
