Munz01 Posted August 17, 2024 Share Posted August 17, 2024 So when I’m doing a test on ping optimiser I get for example 7ping on 70% speed congestion but at the end even tho the lower ping was 7 on 70% it will say the best ping/settings is on 99% speed congestion?? This happens everytime.. here’s 2 pics below; as you can see I was getting the best ping on 87% but the router chose 99% ?? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 17, 2024 Administrators Share Posted August 17, 2024 That is something we're aware of, it should be better on the Early Access version, would you like access to this? Alternatively you could make the change to the percentage manually after finding out the best percentage in the meantime while you wait for firmware to go public. Link to comment Share on other sites More sharing options...
Munz01 Posted August 17, 2024 Author Share Posted August 17, 2024 I’m always down to try it mate Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 17, 2024 Administrators Share Posted August 17, 2024 Added, you can find it here: https://forum.netduma.com/forum/151-netduma-r3-early-access/ Link to comment Share on other sites More sharing options...
iOrcus Posted August 18, 2024 Share Posted August 18, 2024 On 8/17/2024 at 4:53 AM, Netduma Fraser said: @Netduma Fraser why i cant still go below 50% ? is there gonna be any changes to this? thanks Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 18, 2024 Administrators Share Posted August 18, 2024 Yes we will allow for this to go below 50% in a future update iOrcus 1 Link to comment Share on other sites More sharing options...
iOrcus Posted August 19, 2024 Share Posted August 19, 2024 Thanks Netduma Fraser 1 Link to comment Share on other sites More sharing options...
emopi84 Posted September 16, 2024 Share Posted September 16, 2024 Hi Mr Fraser, please give me Early Access version to R3:) THX Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted September 16, 2024 Administrators Share Posted September 16, 2024 52 minutes ago, emopi84 said: Hi Mr Fraser, please give me Early Access version to R3:) THX Added Link to comment Share on other sites More sharing options...
