Administrators Netduma Fraser Posted September 29, 2024 Administrators Posted September 29, 2024 Sorry for the late reply, I've given you Early Access for you to try: https://forum.netduma.com/topic/56955-new-early-access-firmware-r3-dumaos-40290-geo-filter-fix/ Which has a Geo-Filter fix that might help. If not we're testing a cloud update we can get you on to try. thahyp 1
thahyp Posted October 2, 2024 Author Posted October 2, 2024 On 9/30/2024 at 2:07 AM, Netduma Fraser said: Sorry for the late reply, I've given you Early Access for you to try: https://forum.netduma.com/topic/56955-new-early-access-firmware-r3-dumaos-40290-geo-filter-fix/ Which has a Geo-Filter fix that might help. If not we're testing a cloud update we can get you on to try. Thank you, I'll be trying it right now.
thahyp Posted October 2, 2024 Author Posted October 2, 2024 So for Halo MCC, when I disable Geo-Latency it doesn't even show the servers, and says unavailable on the menu, and when I search it kicks me back to lobby. But when I enable it it allows me to search and all the servers are available normally, but I get servers outside the radius everytime.
Administrators Netduma Fraser Posted October 3, 2024 Administrators Posted October 3, 2024 On 10/2/2024 at 11:32 AM, thahyp said: So for Halo MCC, when I disable Geo-Latency it doesn't even show the servers, and says unavailable on the menu, and when I search it kicks me back to lobby. But when I enable it it allows me to search and all the servers are available normally, but I get servers outside the radius everytime. That is normal behavior, it will not work without Geo-Latency. It is possible to get servers outside your radius with Geo-Latency but we are looking into why this is happening with Halo more often than not - they're one of the only games that has actively put procedures in place to prevent Geo-Filtering so it's a bit of a battle. thahyp 1
thahyp Posted October 3, 2024 Author Posted October 3, 2024 I understand but please find a fix for Halo, as it's a game that a lot of people would buy the Netduma for if it supports it fully.
