gearsniper550 Posted June 20, 2024 Posted June 20, 2024 I just got my r3 and I have a question I play different games like defiant, mw3 and halo. Do I have to make my pc a playstation like before.
Administrators Netduma Fraser Posted June 20, 2024 Administrators Posted June 20, 2024 You don't have to no, just be aware that xdefiant won't filter properly, it's something we're looking into but it will take some time and may not be possible
gearsniper550 Posted June 20, 2024 Author Posted June 20, 2024 So even if I have the filter set to cod series it will still filter halo, etc
Administrators Netduma Fraser Posted June 20, 2024 Administrators Posted June 20, 2024 No you'd need to change it over when you switch games
gearsniper550 Posted June 20, 2024 Author Posted June 20, 2024 How would I do that would I have to delete the device and re add it every time
Administrators Netduma Fraser Posted June 21, 2024 Administrators Posted June 21, 2024 Yes that's how you would have to do it - if you don't want to do that you can just do the console method instead like before
