damienv1 Posted June 18, 2024 Posted June 18, 2024 Hello so I’ve done some research and can’t really find much, I currently only have access to LTE and am using a Orbi & a nighthawk m1 I’m working if any of them are compatible to use with the XR500?, thanks.
Administrators Netduma Fraser Posted June 18, 2024 Administrators Posted June 18, 2024 As long as the XR can be connected via ethernet to an existing modem/router it will work - I think there have been some people that use it this way in the past
damienv1 Posted June 18, 2024 Author Posted June 18, 2024 I connected it today via my Orbi lte in port 1 as WAN and the xr500 internet light stayed orange and didn’t show in wifi list
Administrators Netduma Fraser Posted June 18, 2024 Administrators Posted June 18, 2024 Just to clarify, port 1 on the Orbi or port 1 on the XR? As it'd need to be the internet/WAN port on the XR - you will need to go through the XR Setup Wizard before you can get internet
