Hello, I noticed that the connection speed is slow. My plan is 1Gb and when I tested the connection the upload speed was 16 Mbps and upload speed was 9 Mbps.
What is the cause and how to fix it? Thank.
What router and firmware version are you on? Are you testing the speeds on the router or on a site like speedtest.net? Are you testing over WiFi or ethernet?
