XXGodCOD Posted May 17, 2024 Posted May 17, 2024 Â Hello I recently bought the netduma R3, my ping does not want to stabilize with the standy ping option, I need help please because the option says that it does not want to connect to the server where I plays
Administrators Netduma Fraser Posted May 17, 2024 Administrators Posted May 17, 2024 Steady Ping doesn't impact whether you connect to the server or not so you'll still be connecting to it. Not every server can be stabilized but we're working to improve that where possible
XXGodCOD Posted May 17, 2024 Author Posted May 17, 2024 my ping does not want to stabilize in my servers with the stabilizer on the right
Administrators Netduma Fraser Posted May 17, 2024 Administrators Posted May 17, 2024 I understand, that is what I am referring to. What is the ping showing for you?
XXGodCOD Posted May 18, 2024 Author Posted May 18, 2024 why did he write his please, I don't understand
XXGodCOD Posted May 18, 2024 Author Posted May 18, 2024 all game is « couldn’t ping server » what do I have to do
Administrators Netduma Fraser Posted May 18, 2024 Administrators Posted May 18, 2024 Sometimes it's impossible to ping a server, I've given you Early Access, try the firmware there https://forum.netduma.com/forum/151-netduma-r3-early-access/
Administrators Netduma Fraser Posted May 18, 2024 Administrators Posted May 18, 2024 Go there, find the new firmware and upgrade to that
XXGodCOD Posted May 18, 2024 Author Posted May 18, 2024 what should I do with this early access? Because I play on xbox
Administrators Netduma Fraser Posted May 19, 2024 Administrators Posted May 19, 2024 You install it on the router itself, it has install instructions on the firmware post
XXGodCOD Posted May 19, 2024 Author Posted May 19, 2024 I installed the version and nothing changes I don't understand IMG_1039.mov
Administrators Netduma Fraser Posted May 19, 2024 Administrators Posted May 19, 2024 There will be a new version on Monday you can try with improvements to this feature
