I have a xr500 i want to update it to a beta firmware-- currently the firmware is "XR500 V2.3.2.134" i need to lower my ping on fortnite... any tips will help
I have a xr500 i want to update it to the latest beta firmware, i hear i need to make a post here about it... any other tips to lower ping on fortnite would be greatly appreciated
@Pratush
I can tell you what worked for me when it comes to updating to the newest version (beta) for the XR500
I'll try and make it as simple as possible.
1. Login to XR500
2. Settings (Tab), Administration, Firmware Update
3A. Click (Browse)
3B. Then find the Intermediary_Firmware and Upload
Link for Intermediary_Firmware - https://www.dropbox.com/s/hpeb2w2m4mvmv3q/INTERMEDIARY_FIRMWARE.img?dl=0
4. Once update (Intermediary_firmware) has been completed and you have access to the DUMAOS interface, pelase repeat steps 1-3A
5. Then find the RC14_Firmware and Upload (This step did not work for me)
Link for RC14 - https://www.dropbox.com/s/n5nk0fxkhzosvp2/XR500-V2.3.2.134-dumaos33-rc14.img?dl=0
6. This is how to Update if nothing goes wrong, For me things did. So ill explain how i overcame those obsticales, and you can try as this solution worked for me.
7. Since trying to upload RC14_Firmware did not work (I got an error after trying to upload it)
8. Then i tried the 2nd Route
9. Repeat Steps 1-3A
10. Then find the RC10_Firmware and Upload
Link for RC10 - https://www.dropbox.com/s/mb7hztmwpxnpz2i/XR500-V2.3.2.134-dumaos33-rc10.img?dl=0
11. When clicking apply or yes to update this version of firmware, it may say "are you sure you want to update to older firmware" , Click yes
12. Once RC10 is loaded and you have access to the DUMAOS Interface, please repeat steps 1-3A
13. Repeat Step 5
!4. If done correctly which to be honest the time it actually worked for me was no different from the other 10 times i emplemented Steps 1-13. So as to why it worked. Just not gonna ask questions and move on as, my way may be unique to just me, But i know it works. And i know it will work for others.
Hope this helps, and as of Fortnite ping issues, if you're on console, just as your console to the geo filter (if fornite is not an option, doesn't matter, just need the console to be selected)
I personally created a rule for myself and i think it worked wonders as i play on console and play rocket league. Keep me updated, i would like to know if my way (steps wise) works for you.
