GinjaBrad Posted April 19, 2024 Share Posted April 19, 2024 I was able to create one before and now it does not work by going to the save and share function in google. I could use help finding a work around thanks for your time Link to comment Share on other sites More sharing options...
GinjaBrad Posted April 19, 2024 Author Share Posted April 19, 2024 I managed create one but it has the google chrome icon how do I get the netduma icon? also cant pin it to my taskbar with this type of shortcut. any help would be appreciated thanks again Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 19, 2024 Administrators Share Posted April 19, 2024 Pretty certain you'll need to open it then once opened on the taskbar you can then right click it to pin. I think if you right click and go to properties you can then change the icon - you'll probably need to download our logo from Twitter to do so Link to comment Share on other sites More sharing options...
