so I have found 2 servers I like playing on & have blocked the ones i don't like
is there any way when searching for a game I could auto-connect to the servers without waiting forever & skip the game trying to connect me to the servers that are blocked
i just want to search for a game & it connect to the servers i dont have blocked without having to wait for 20min till it finds that server
many thanks
No way to do that unfortunately, the game will always try to connect you based on whatever its parameters are and then when it can't it'll go with what you can connect to. 2 servers really isn't a lot, you're really banking on there being space for you/them not being overloaded etc at the time you play so I would definitely recommend trying to find other servers that play well for you.
