Moto67 Posted February 14, 2024 Share Posted February 14, 2024 I’m playing Fortnite on Xbox series x and I keep getting connected to Washington DC servers. In the ping heat map, I don’t see any Washington DC Fortnite servers but you can see that I’m up to ten blocked. Is this a bug? The reason I am trying to avoid Washington DC servers (not shown in heat map) is because ping heat map shows great connection to Norfolk Virginia servers. Im on the latest firmware 4.0.41 Link to comment Share on other sites More sharing options...
ChrisG82 Posted February 14, 2024 Share Posted February 14, 2024 I would rather say that one of the two adverts is simply wrong. They will be the same servers. Link to comment Share on other sites More sharing options...
Movement Posted February 14, 2024 Share Posted February 14, 2024 10 hours ago, Moto67 said: I’m playing Fortnite on Xbox series x and I keep getting connected to Washington DC servers. In the ping heat map, I don’t see any Washington DC Fortnite servers but you can see that I’m up to ten blocked. Is this a bug? The reason I am trying to avoid Washington DC servers (not shown in heat map) is because ping heat map shows great connection to Norfolk Virginia servers. Im on the latest firmware 4.0.41 Connecting you to this server because this is Xbox Microsoft server this is nothing to do with fortnite or games you playing this servers is for Xbox and Microsoft service like game pass voice party and more it's not possible to block this server otherwise you will have issues with voice party and other things Link to comment Share on other sites More sharing options...
Moto67 Posted February 14, 2024 Author Share Posted February 14, 2024 Thanks. With Washington DC being an xbox server, is it possible to see which Fortnite server I am connected to? Link to comment Share on other sites More sharing options...
xNotTheBestJedi Posted February 15, 2024 Share Posted February 15, 2024 The server you are connected while ingame should appear as a white controller icon on the map. White circles represent pings to other servers, like the xbox and NAT servers you are not connected to these. The yellow triangles are blocked servers. Hope this helps. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 15, 2024 Administrators Share Posted February 15, 2024 It's most likely an authentication server in that location - when you see it do you have another icon appear on the map within your radius? Link to comment Share on other sites More sharing options...
Moto67 Posted February 16, 2024 Author Share Posted February 16, 2024 8 hours ago, Netduma Fraser said: It's most likely an authentication server in that location - when you see it do you have another icon appear on the map within your radius? here is what I am seeing. Link to comment Share on other sites More sharing options...
xNotTheBestJedi Posted February 16, 2024 Share Posted February 16, 2024 Do you have GeoLatency on? if so, turn it off. Does the icon looks like a white circle with a black check sign before it connects or just a full white circle? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 16, 2024 Administrators Share Posted February 16, 2024 Not an authentication server then no, do you have the ID for it? Then I can check its location. If you disable Geo Latency filtering won't work at all for Fortnite Link to comment Share on other sites More sharing options...
Moto67 Posted February 16, 2024 Author Share Posted February 16, 2024 23 minutes ago, Netduma Fraser said: Not an authentication server then no, do you have the ID for it? Then I can check its location. If you disable Geo Latency filtering won't work at all for Fortnite I will check this weekend. The other 10 Washington servers showing in the same location are in my original post/photo above, in case that info is helpful. This would be the 11th one if I were to deny it. Netduma Fraser 1 Link to comment Share on other sites More sharing options...
