high ping and random lag and filter not working
ryekye
 Share
I'm getting high ping when searching for games and when in game i get lag every so often and it's weird to have that happen its bothering had 0 issues with xr500 so hoping these issues get fixed I use the geo filter alot and it's always connecting me outside filter with geo latency enabled and steady ping it's weird
When finding matches it says about 130 ping and up then when in game goes up to 1000 then drops down it's a weird ping spike and it isn't my internet either
3 hours ago, Netduma Fraser said:
If it is CoD you're playing, it's very likely due to the season 2 update, a big influx of players causing strain on the servers. Try direct to the modem and see if you get the same thing.
Ok and y is the stabilized ping thing being weird too and what's geo latency do do I leave that on or no and I'm connecting to stuff outside my circle so how do I fix that
It happens on other games aswell so it has to be the router.
How is the stabilizing of the ping being weird? Geo-Latency is just a different method of filtering.
  1. Disable GeoLatency
  2. Disable PingAssist (set it to 0,0)
  3. Enable Strict Mode
  4. Disable Fast Search
Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then.
What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode
And when do you think these features will be available?
When do you think they will do what they are supposed to? When I turn it on, it makes my gaming experience worse. I thought they were there to improve your connection or to at least “assist.” When you tell me that I need to turn a feature that is supposed to improve your experience off, my understanding is that they are not working as intended.
Am I not understanding something here?
Oh I see, well Geo-Latency is just a different method of filtering so you're essentially swapping between two filtering methods when disabling it. One or the other may work better for you. Steps 2-4 by default are already set that way.
I'll try with geo latency off and see what happens and also 2 and 4 are already off!
The high ping lobby on CW3 happened to me again 133 ping then it connects me to a server in another country, R3, I have to restart the PS5 3 times, take off the PS5 from Geo filter then add it back. Could not get normal ping, gave up for tonight. Hopefully it will get good on the next update along with the wifi issues
Is it the r3 possibly or the game?
I don't think it's necessarily the router in this scenario, I am pretty confident it's on the game side. If nothing has changed on your end and the only thing that has changed is a game update that would indicate its the issue
I have not ran into the high ping part on the xr1000 only the r3 so far I'm hoping it's a easy fix and with geo latency on my filter radius doesn't work it allows stuff outside my circle too but the router works great just annoyed of the high ping no matter what game I play it says I have over 50 to 180 ping when I usually always have 50 and under like fortnite my ping is usually 22 on the server it's always now saying 130 and cod when I search it'll search normal one time then jump up to ridiculously high ping like 200 for searching and always stays that high up I'm hoping that's just a bug because I never really had a issue with the xr1000 besides slow interface and the xr500 no issues either besides the dumaos not loaded repetitive thing to where you had to redo firmware to fix it
5 minutes ago, Netduma Fraser said:
Are you both on the .41 firmware?
Yes I'm on .41 firmware and did factory reset after upgrading to it and did a 3rd reset to make sure still having the exact same issues
Its definitely the router cuz I used my asus and xr1000 and it never did that at all was perfect searching games and even in game was good on asus and xr1000 so it's a r3 issue I'm hoping it's fixed soon I just bought mine
42 minutes ago, Netduma Fraser said:
What are your Congestion Control/SmartBOOST/Geo-Filter settings? Is this the ping on the Geo or in game?
100% on cc smart boost is on and geofilter is on even the geo latency setting and the steady ping
100% won't be doing anything, do 70% and see if it is any better, disable Geo-Latency and Steady Ping, then try again
Ok will try but last time I did that it didn't help either it still was high ping and I'm on 1gb fiber so the ping optimizer recommended 100%
29 minutes ago, Netduma Fraser said:
Keep us posted! Disable those Geo options also
Ok I'll try it out disabling the geo latency and just use regular filter and will mess with cc to see how it works even though I'm on 1gb fiber up and down
 Share
