DeeKay_FPS Posted February 8, 2024 Posted February 8, 2024 I just noticed disabling smart boost literally doubled my download. ( My connection speed is 500 MBPS ). I thought this was addressed in the new patch. Should I keep it off ? May I know what's the best settings.
Espi411 Posted February 8, 2024 Posted February 8, 2024 how did in game situations feel? or did you turn it back on for ingame?
Administrators Netduma Fraser Posted February 8, 2024 Administrators Posted February 8, 2024 What are your Congestion Control/SmartBOOST settings?
DeeKay_FPS Posted February 8, 2024 Author Posted February 8, 2024 1 hour ago, Espi411 said: how did in game situations feel? or did you turn it back on for ingame? It feels the same.. I don't see any difference. Does smart boost imapct the game or ping ?
DeeKay_FPS Posted February 8, 2024 Author Posted February 8, 2024 44 minutes ago, Netduma Fraser said: What are your Congestion Control/SmartBOOST settings? I did not touch the congestion control. My smart boost was enabled when I updated the software. I did not play with the smart boost settings at all. All I did was switch it off and the download speed is back to normal as provided by the ISP.
DeeKay_FPS Posted February 8, 2024 Author Posted February 8, 2024 Please guide me how to configure it.
Administrators Netduma Fraser Posted February 8, 2024 Administrators Posted February 8, 2024 Did you run Ping Optimizer either during the wizard or after though as this would have set Congestion Control for you and would then potentially explain why as it does limit bandwidth speeds to eliminate lag/bufferbloat
DeeKay_FPS Posted February 9, 2024 Author Posted February 9, 2024 I used the ping optimizer during wizard. But everything was done automatically by the OS.
Administrators Netduma Fraser Posted February 9, 2024 Administrators Posted February 9, 2024 Okay well that's probably why then, it lowers Congestion Control to eliminate lag. You can adjust this in Ping Optimizer > Advanced if you re-enable SmartBOOST
DeeKay_FPS Posted February 9, 2024 Author Posted February 9, 2024 4 hours ago, Netduma Fraser said: Okay well that's probably why then, it lowers Congestion Control to eliminate lag. You can adjust this in Ping Optimizer > Advanced if you re-enable SmartBOOST Thanks for your response. Do I have to crank the download and upload all the way up in expert settings under ping optimizer ? Just looking for an optimal settings.
Administrators Netduma Fraser Posted February 9, 2024 Administrators Posted February 9, 2024 Expert relates to the Ping Optimizer test specifically. You'd have to re-enable SmartBOOST to adjust the Congestion Control sliders, if you're wanting full speeds then they should be at 100% but it won't combat bufferbloat set like that. DeeKay_FPS 1
